Chevelle Tech - View Single Post - 68 Chevelle convertible power top wiring
post #3 of (permalink) Old Aug 11th, 19, 8:32 PM Thread Starter
Billdini
Re: 68 Chevelle convertible power top wiring
Originally Posted by VinceS427bb View Post
it has been awhile since i worked on mine.
the power for the top does not go thru the fuse box wiring.
was a separate 12awgfrom the horn relay bus;
going to a thermal relay on firewall attached near brake master cyl.
then it went thru a grommet into the interior directly to the top power switch.
the top power switch would switch polarity of power going to the top motor;
this allowed the top motor to run either up or down with only 2-wires,
IIRC these 2-wires wire extra; but went thru the plastic sheath to rear of interior under carpet...
is this a power top frame ??
i cannot recall if there were 2-versions of the frame..
but until i got my top motor working i disconnected the top cylinders from the top frame.
it was fairly easy to fold and lift the top frame
one person on each side made it even easier; watch for pinch area on fingers
Hi Vince, thank you and after you supplied this info I went out to M&H and priced out the 3 harnesses and circuit breaker that I need. No its not a power top frame but I think only the piston shoulder bolt is different. I can certainly be wrong. Man they really didn't think out the harnesses in the old days requiring additional power leads for almost any power accessory. Oh well. Thanks again
Billdini is offline
