Chevelle Tech - View Single Post - 68 doors on my 69 2dr hardtop - help...
post #16 of (permalink) Old Jul 23rd, 19, 9:20 PM
cheveslakr
jerry
Re: 68 doors on my 69 2dr hardtop - help...
If you have the '69 300 Deluxe 2dr sedan, then your doors, if '69, should have the same regulators as a '69 elcamino and I'm assuming the same as '68-'72 A body 2dr sedans and elcaminos. I pulled the guts from a '71 buick skylark post car and they used the same regs. The regs should have a stamped 27-78 and 27-79, respectively on the main arm, not sure which number belongs on which side of the car. The pivot arm should have a 27-80 stamped no matter which side the regs belong to.
I'm assuming the '68 300 sedan post cars would use the same regs, but not sure. Not sure you can purchase elky regs. To determine which year doors you have, look closely at the inner structure and you will see a code and date code. Post those numbers and we can help further.
cheveslakr is online now
