Chevelle Tech - View Single Post - Daytona Sensors question
post #2 of (permalink) Old Jul 17th, 19, 7:08 AM
GuysMonteSS
Guy
Re: Daytona Sensors question
Yes it is a multi-spark ignition.
You're right that it doesn't come out and say so but if you read the instructions on page 12 it does mention the multi-spark feature.
Also on page 16 Figure 13 -Module parameters you can see where you have the option to disable the multi-spark feature.
It is an awesome system,and once you have it programmed it is relatively easy to change parameters and timing curve.
Guy
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
