Chevelle Tech - View Single Post - Finding Vacuum Leaks
post #1 of (permalink) Old Jul 16th, 19, 3:41 PM Thread Starter
mdelgado
I'm pretty sure I have a vacuum leak somewhere given my poor idle and performance with my aftermarket FI. I used some carb cleaner and sprayed around the base of the throttle body. i also sprayed where the intake meets the heads and didn't hear a change in performance. Anyone have a punch list of most prone leak areas and what they'd check first? also, is carb cleaner good to use or should i use something else?
67 Chevelle 454, M21
Gen IV 454 (out of C30 ), 390 heads 1.88/2.19 valves by Vortecpro, with ISKY Hyd Roller cam (at 050 218 int./228 exh, lift 530 int./552 exh.), RPM performer intake, Fitech 600HP, Dougs headers, and M21, Gear Vendors OD, 3.73's, UMI Suspension, Viking coilovers.
mdelgado is offline
