Chevelle Tech - View Single Post - need help with heat issue in the cab please!!!!!!
post #4 of (permalink) Old Jul 14th, 19, 10:43 AM
hjdca
Harry
Re: need help with heat issue in the cab please!!!!!!
Originally Posted by Treyton75 View Post
so i have a 1981 camaro that is motor swapped with a 427 BBC an the car runs good and is solid however ive noticed that after driving at about 50-60 for awhile or just driving in genaral the driver side foot well heats up fast i know this is due to the headers warmming up how should i go about reflecting the heat so i can drive with out having my feet roasted????? (it is carb no blower or turbo..............yet)
If the headers are super hot and discoloring, then, the new motor could be running retarded and blowing gas into the headers. What is the timing ? If big cam, advance the initial timing which will help you close the throttle blades and reduce fuel at idle.
Harry
hjdca is offline
