Chevelle Tech - View Single Post - Umi 4062
Thread: Umi 4062
post #5 of (permalink) Old Jun 13th, 19, 5:46 PM
Eddie K
Eddie
Re: Umi 4062
Originally Posted by Jasons 69 Chevelle View Post
Is the T-Bar mount removable from the qa1 coil overs. I have aftermarket suspension now. I plan on increasing the spring rate and would like to go with this design. I seen the 1/2 rod end shocks are required. But donít see any part numbers Or shocks on their site with 1/2 rod ends.
T bar mount is removable from QA1 coilovers.
On my Cutlass I have QA1 Control Arms. Lower CA has a coilover mount that bolts in, which requires T-bar to be removed.
It's a really great design since you can convert it back to stock style shock/spring just by removing the mount.
Name:	Messages Image(1868258716).png
ID:	595626   Click image for larger version
Eddie K is offline
