Chevelle Tech - View Single Post - Umi 4062
Thread: Umi 4062
post #2 of (permalink) Old Jun 13th, 19, 10:57 AM
Blown1932
Allen
Re: Umi 4062
Originally Posted by Jasons 69 Chevelle View Post
Looking at these front lower control arms. I couldn’t find instructions on UMI web site. Does the 2 bolt mount on bottom of the shock just get pressed out and installed on the lca mounts?
I Just read the description on UMI's site. The referenced arms are for use with 1/2" rod end coilovers, if you are planning on using stock style mounting shocks, look at one of their arms designed for that.
I wish my arms were set up like the 4062 with removable lower coilover shock mounts as it would make playing with the rate of coilover springs (changing springs on the coilover) very easy.
Blown1932 is offline
