Chevelle Tech - View Single Post - Best way to cut the urethane wave
post #14 of (permalink) Old May 23rd, 19, 6:39 PM Thread Starter
65conv
Curt
Re: Best way to cut the urethane wave
Originally Posted by modern malibu View Post
To cut urethane wave properly, I start with 800 grit and use a long block just as you would when blocking primer. Using a short block can create small valleys, further enhancing the wave. The key is long block sanding in diagonal directions to cut the highs off evenly, throughout the entire panel. You must have at least 3 good coats of clear to start with 800. Only light pressure should be needed to cut the clear with 800 grit. Lots of water with dish detergent added will help keep the paper lubed and clean. See pics in my garage of my black car and you will see what can be accomplished in home sprayed project
Thank you
65conv is offline
