Chevelle Tech - View Single Post - 65 SS Chitvelle - My PT attempt
post #467 of (permalink) Old May 22nd, 19, 3:09 PM Thread Starter
Dan65ss
Re: 65 SS Chitvelle - My PT attempt
Originally Posted by Jeff65SS View Post
Hi Dan, what fuel tank are you using?
Hey Jeff,
I went with a super cheap dorman tank from RockAuto as I wanted to use the Aeromotive Phantom setup I had purchased already. I think the tank only cost 73 dollars when I got. But because the fittings from the fuel hat sit up so high without a recessed top panel it needs to be spaced down and then longer straps are needed. So I might grab another tank with the recessed panel on it, or I might cut and weld....or just space it down some...
DORMAN 576073 (576-073)
Build thread-
Album -
Dan65ss is offline
