Dennis
Re: Best way to bleed brakes
So here is another question that may be related...
Each of the calipers have 4 bleeder screws, top and bottom, inside and outside. 16 screws total.
I have been bleeding the brakes with the wheels on the car so only bleeding the top inside bleeders screws on each caliper, which now have speed bleeders.
Should I bleed the top OUTSIDE bleeder screw too? It seems like there could be air in there without a path to the inside bleeder.
It would be nice (although embarrassing) if this were the issue because it seems like a simple fix.
