Chevelle Tech - View Single Post - Need Help Diagnosing Popping
post #13 of (permalink) Old Apr 23rd, 19, 11:56 PM
blown70
Travis
Hey bud why not start by firing it up and then pull #1 plug wire. See what that does to the pop. At least you can verify the cylinder. I’m thinking ignition...go around your cap and make sure your firing order is correct. I’ve seen sillier things happen. I’ve also seen wires backwards and not backfire so worth a check.
Don't let fear and common sense stand in the way of MORE POWER!
Travis
blown70 is offline
