Chevelle Tech - View Single Post - Tips to be faster at the track
post #13 of (permalink) Old Apr 19th, 19, 2:51 PM
Kirk's67SS
Greg.
Re: Tips to be faster at the track
Hunter
DA Shocks are a good idea but after going that expensive way I decided to go Old School Cheap
I put some Moroso Trick Front Springs and Comp Eng 3 Way Adj Shocks set at 80/20
on the Rear I put some Comp Eng 3 Way Adj Shocks set at 50/50 with Stock replacement Springs from Moog and Air Lift 1000 Air Bags inside them,
add Air in them depending on Track conditions
Got the Front Wheel off of the ground on Launch, Launch at/off Idle & only have a 2,500 Stall Converter,
so a good transfer of Weight towards the Rear has happened as there is no more spinning of Tires on Launch
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is offline
