Chevelle Tech - View Single Post - 12 Bolt Upgrade
Thread: 12 Bolt Upgrade
post #15 of (permalink) Old Apr 11th, 19, 7:38 AM
jackie schmidt
jackie
Re: 12 Bolt Upgrade
Originally Posted by 800XCR View Post
I'm having my 12 bolt updated to have the large Ford bearing ends to eliminate C-clip concerns. I also want to add disc brakes at the same time. What setups have been used with success. I will still be using 15x8 ralley wheels.
I had Pyle Brothers in Baytown do my 12 bolt. The put Ford ends on, added Wilwood disc, Moser Axels, and best of all, the Eaton TruTrac.
Great setup. The TruTrac requires no additive, is super strong, and it does what a good Posi is supposed to do.
jackie schmidt is online now
