Chevelle Tech - View Single Post - 12 Bolt Upgrade
Thread: 12 Bolt Upgrade
post #6 of (permalink) Old Apr 9th, 19, 2:29 PM
nashville beth
Beth
Re: 12 Bolt Upgrade
From the Moser Engineering website :
Can C-Clip Eliminators be used on the street?
A. We do NOT recommend using C-Clip Eliminators for street use; a C-Clip Eliminator is made for drag race only ( As a safety issue so you do not loose an axle, if it breaks ).C-Clip Eliminators are made for the straight shot down the strip. If you use C-Clip Eliminators on the street the aluminum block will eventually flex from cornering or just going around curves causing the C-Clip Eliminator to leak Rear-end fluid.
nashville beth is offline
