Chevelle Tech - View Single Post - Where to buy 12 bolt?
post #21 of (permalink) Old Apr 1st, 19, 9:05 AM
Lew540
Lew
Re: Where to buy 12 bolt?
I think if you get the right parts from Moser it can take a lot more power than the stock 12 bolt. They have fixed all the areas that are know problems with 12 bolts. Weak house, 33 or 35 spline axles versus the 30 spline, Ford end bearings, Robust posi unit, 1/2 inch studs holding the carrier in, 1350 series U joint. It has 12 bolts on the back cover but I think that is about where it stops on what they left original on the rear. The ring gear still is 8.875 so that could be an issue. Ford 9 inch is a proven piece. Of course the Dana 60 is such a massive unit to begin with you really don't need anything with the S60.
Lew540 is offline
