Chevelle Tech - View Single Post - Best radio and wiring harness
post #3 of (permalink) Old Mar 28th, 19, 7:07 AM Thread Starter
barkerpa3466
Paul
Re: Best radio and wiring harness
Originally Posted by Cubsfan3493 View Post
Can't speak for the radio because I am wiring a modern one into my car, but my American Autowire harness I have had no problems with and everything is well labeled and easy to understand. I currently have an LS swapped engine, but just so you are aware, the engine module is completely separate from the rest of the wiring. There are a few wires from the harness which you will use, but for the most part it doesn't matter what harness you get, it will all work the same with the stock engine or an LS engine because you need an ECU for an LS engine. Good luck!
Hunter
Sent from my Phone 2 using Tapatalk
Thank you. I know that when I do the swap that the engine will need its own computer and all the sensors that go with it to make it happy, I just want to make sure that I future prof a little and make sure that I get enough circuits so that I am not piggy backing of ones that are already used kida like what is going on in my car now.
what radio are you putting in does it fit in the dash nicely?
barkerpa3466 is offline
