Chevelle Tech - View Single Post - Spitting back through carburator
post #18 of (permalink) Old Mar 26th, 19, 9:21 AM
427L88
Re: Spitting back through carburator
Disaster narrowly averted!
Hey, I think Harold hit on it,....... the balancer will show TDC TWICE in a full revolution ( these are 4 stroke engines, right).... so its likely you are sitting on #6 TDC ( 360 out). You can verify by popping the drivers side valve cover and eyeballing #1 valves, THEY SHOULD BE CLOSED. I hope you find them hanging open, which means you are at #6. BTW, you can check the degree of the cam while its parked in #6 TDC. You want to see the INTAKE valve slightly more open ( closer to the head surface) than the EXHAUST.
Now, if you find the valves closed on #1,and that is the TDC you were using, then I suspect you have misadjusted valves, and I would have Leo drop by. Its a "feel" thing to set them, esp hydraulics. You'll ahve to go through the whole IO/EC procedure for all 16.
It is convention to have #1 plug post pointed at #1 cylinder, but it really is of no issue.
