Chevelle Tech - View Single Post - 70 fuel guage wire color? behind dash
post #4 of (permalink) Old Mar 19th, 19, 5:58 PM Thread Starter
Strip Poker 388
Rob
Re: 70 fuel guage wire color? behind dash
Thanks for the info, I seem to remember the lime green wire on radiator support going to the high beams also.ill ck see if indicator is working,blue light? It has the idiot light for engine temp, I assume its not hooked to anything with no sensor for it anymore. Might be a stereo wire not hooked up either.
Ill have to pull the cover off below steering column see where it goes,tan wire?
Does anybody have a wiring schematic for that area ,column/fuse/dash cluster?
At the sending unit I read 8.4vts on the hot side/tan wire, i ran outa time to finish testing it.
Thanks for all the help
Rob
Strip Poker 388 is offline
