Chevelle Tech - View Single Post - 65 SS Chitvelle - My PT attempt
post #439 of (permalink) Old Mar 15th, 19, 8:01 PM
1965_ss
Todd
Re: 65 SS Chitvelle - My PT attempt
Originally Posted by Dan65ss View Post
I am thinking a 10 inch rim will be about right, maybe only a 9. I haven't measured from hat to hat. My rear end is 51" I believe, if I remember correctly. I have also been eyeing those RB3C wheels. And you are right, this thing will probably get some forgelines...if I trust my measurements enough when ordering.
I will most likely go with the 295s for the rear.
51" !! Are you sure???? That is SUPER narrow.
My rearend is something like 57", I ordered it 3" under stock. I did this because I didn't want a super deep lip on the back rims. Look at my pics and you will see. You have to take into account the thickness of the rotors you are going to use also. So know what brakes you are going to run.
Aaron's old stock frame was narrowed like 1.5" per side (not 2" like the current ABC kit). I believe he used a 10.5" with that 295 in the beginning. You should talk to him and find out the real deal and see what you should run.
RB3C!!! cool, do it up!!! I came real close to buying the VX3C.
_____________________
Todd
1965_ss is offline
