Chevelle Tech - View Single Post - 496 help
Thread: 496 help
post #12 of (permalink) Old Mar 13th, 19, 3:58 PM
Malibu ss 64
Marcus
Re: 496 help
Originally Posted by bracketchev1221 View Post
If it was me, I would go to 489 if the block is standard bore. Don't bore it more than you have to.
Same here bore .030 if standard bore block.
Used a couple of kits from Skip White in engines I assembled for friends and one I sold decent for the money all are still running one since 2010(and that one had pro Comp rods before he started using scat).
I would go with Brodix race rites 312 over Promaxx, Brodix is Us cast and all sets I used has worked great check with Mike Lewis aka wolfplace or Eric weingartner they might save you a buck on the heads recomend size 270 ovals 294 or 312 rec and Mike can pick you a cam that fits your goal.
https://lewisracingengines.com/
Weingartner Racing
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
