Chevelle Tech - View Single Post - Main harness routing for '66
post #4 of (permalink) Old Jan 21st, 19, 6:55 AM
Don B
Don
Re: Main harness routing for '66
Were any of the original harness retainers still attached to the harness? If so that should give you an idea where they should plug into the holes.If I remember correctly there are two small metal retainers that go around the harness wires for the radio,blower resistor and heater-fan switch and near the radio and there are two mounting holes that use small screws to attach them. Isn't there holes in the rear of the cluster taht that plastic retainers push into? Keep us posted.
Don B is offline
