Chevelle Tech - View Single Post - Ignition Switch for '68 Chevelle needed.
post #22 of (permalink) Old Jan 18th, 19, 2:02 AM
Billdini
Re: Ignition Switch for '68 Chevelle needed.
Hi Frank I do remember back away"s that you did have to match your metal insert that screws into the new chrome plastic threaded bezel. I did not have to do to do that and I just removed my old metal insert that screwed into my old plastic chrome bezel (fine threaded) and threaded into my new threaded ignition chrome surround. I was good to go after that and nothing is loose and the ignition key is oriented correctly using a new white ignition switch. In either case I think you need the correct metal insert for your ignition bezel allowing you to use the new new switches making your life easier although I have never had to replace an ignition switch over the years. Best of luck!
Billdini is offline
