Man dies after car falls on him - Chevelle Tech
 18Likes
post #1 of 23 (permalink) Old Jul 17th, 17, 7:36 PM Thread Starter
Dean
Don't let this be one of us.
Man dies after car falls on him in Adelanto - Victor Valley News | VVNG.com
"Iím the one thatís got to die when itís time for me to die, so let me live my life the way I want to."
Jimi Hendrix
Dean 1961 is offline
post #2 of 23 (permalink) Old Jul 17th, 17, 7:43 PM
Re: Man dies after car falls on him
Last year, I caught my 75-year old neighbor under his 1958 Chrysler Windsor wagon. He had the front wheel off, and the car was only raised with a smaller, old floor jack... He was trying to loosen a brake line (so quite a bit of effort expended)... Oh yeah, the car was on his driveway which has about a 10% slope! Parking brake and a wheel chock, but still...
I gave him grief about not using a jackstand... So next time I saw him under one of his cars, he pointed out the jackstand...
I am paranoid enough, that even with jackstands AND the floor jack, I usually throw the wheel under the frame, just in case something happens...
Ouch!
gspan1830, Buzzbomb, LeoP and 2 others like this.
TC #1366
Sold
Sold
1966_L78 is offline
post #3 of 23 (permalink) Old Jul 17th, 17, 7:50 PM
I usually put two jackstands under em now, this is something that does scare me.
68Cpe307 likes this.
A Body Love!
plugitin is offline
post #4 of 23 (permalink) Old Jul 17th, 17, 10:02 PM
This happens too often and is too easy to avoid. With all the low cost Chinese jack stands there is no excuse for not using them. We lost a guy at a place I worked to this. He failed to show up for work on Monday and then Tuesday. The company called the police for a welfare check on him; too late. I have seen guys take a wheel off a car and lay it flat on the ground and slide it under the car. That is a lot better than nothing.
shovelrick likes this.
JWagner is online now
post #5 of 23 (permalink) Old Jul 17th, 17, 10:54 PM
I always have a minimum of two jack stands under my car, and I usually leave the floor jack in place also unless it is in the way. As soon as the car settles on the stands, I also give it a good shake to ensure it is secure. The other thing that people seem to neglect is eye protection... you know you can't work on it if you can't see anymore!
Kirk's67SS and shovelrick like this.
70 El Camino SS 396/TH400
67 Cutlass Supreme convert LS3/4LE85
65 GTO convert Tri Power 4 speed
65 Corvair Corsa Crown Conversion (Mid engine 350)
05 Silverado 2500 Duramax/Allison
06 GTO 6 speed
11 Honda Accord 6 speed coupe
14 Harley Davidson Electra Glide Ultra Limited
19sixty5 is offline
post #6 of 23 (permalink) Old Jul 17th, 17, 11:02 PM
My buddy's dad was always preaching to us when we were working on cars in his backyard that's why I was so surprised when later his car fell on him and killed him.
They think he was greasing it and when he turned the wheels to be able to get to a zirk on a tie rod it fell off the jack.
post #7 of 23 (permalink) Old Jul 17th, 17, 11:23 PM
My father had his 1949 Nash on a bumper jack with the right front wheel off. He was under the car from the front checking the bottom of the radiator for a leak when the jack dropped the car. It fell on the above ground roots of a giant Sycamore tree it was parked next to. Had it not been for those large roots stopping the car from going all the way to the ground, I wouldn't be writing this as it happened before I came along.
I also use the two jack stand procedure.
Toppless72 is offline
post #8 of 23 (permalink) Old Jul 17th, 17, 11:46 PM
Wayne
Ouch!
I do the same
Ga69abody is offline
post #9 of 23 (permalink) Old Jul 18th, 17, 12:03 AM
Always taught to throw something big underneath (rim or log) when working underneath just in case. Lost a high school friend to a slipped jack.
Instructions...All I need is the exploded view.
Enganeer is offline
post #10 of 23 (permalink) Old Jul 18th, 17, 9:06 AM
Same here. He was removing a 4 speed from a '63 Impala with ONLY a bumper jack! Left a wife and new baby. She found him when he didn't come in for supper.
When I works, I works hard.
When I sits, I sits loose.
augy is offline
post #11 of 23 (permalink) Old Jul 18th, 17, 9:47 AM
I do the same...and am still paranoid when under the car. I climb out several times, shake the car around a little and inspect while having to work on anything that requires me to be down there.
1966 SS 396 4 speed Chevelle
1968 Chevelle Malibu
Family owned since new
BBE66SS is offline
post #12 of 23 (permalink) Old Jul 18th, 17, 10:22 AM
Bart
I use jack stands but I don't trust them 100% either, I have seen jack stands tip over on uneven areas. I use drive on ramps when I can and when I can't, i use jack stands and then slide the ramps up under the frame and leave the jack in place as well.
RAMBO, badrad, Kirk's67SS and 1 others like this.
Bart_Swisher is offline
post #13 of 23 (permalink) Old Jul 18th, 17, 12:06 PM
Ben
THIS!
I don't like jack stands anywhere except under the rear axle... everywhere else they always look like they could slip at any moment.
I have a heavy duty set of reinforced ramps... if my work doesn't require the suspension hanging or removing wheels, I always jack up the car and set it back down on the ramps.
Ben R.
RAMBO is offline
post #14 of 23 (permalink) Old Jul 18th, 17, 12:08 PM
Send a message via Yahoo to ElCameeeno
I stopped using those metal ramps when I drove my Chevelle up on them, got out of the car just as the drivers side collapsed. another couple of minutes and I would have been toast. Now its two jack stands and a floor jack at the minimum.
Jon
TC Gold Member #08
'71 SS454/M22 El Camino
'68 Chevelle/M22
'72 6 cylinder El Camino
ElCameeeno is offline
post #15 of 23 (permalink) Old Jul 18th, 17, 12:19 PM
Originally Posted by Ga69abody View Post
I do the same
x3
Had brand new oversized stands fail for no reason, I always put the jack with some pressure on front/rear just in case.
many yrs ago had a car come down on me was pinned in the trans tunnel, crushed me real good. Thank god there were people nearby dont remember them getting the car back up and being drug out. Dread getting under lowered cars to this day.
cuisinartvette is offline
This Thread is more than 943 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
