Electrical advise needed - Chevelle Tech
 3Likes
post #1 of 25 (permalink) Old Feb 7th, 16, 12:18 PM Thread Starter
Need to add a 20a 240v breaker for a hot water heater, but I have no room in my panel.
Can I swap out more of the breakers for the tandem ones to make room?
ID:	330546   Click image for larger version
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is online now
post #2 of 25 (permalink) Old Feb 7th, 16, 12:41 PM
Re: Electrical advise needed
I would have no issue doing it. You may be able to find a 15-20 quad breaker that will work. It will allow you to have two 15 amp single pole breakers on the outside, with a 20 amp 2 pole breaker in the middle (this one should work:
). The deciding factor will be if the bussing has the cutouts to allow for the another twin/quad type breaker to fit.
My Chevelle w/ open headers:
WakkoWarner is offline
post #3 of 25 (permalink) Old Feb 7th, 16, 1:30 PM
Bryan
You can, but you have to know what you are doing. If you have any multi wire branch circuits and you combine them on a tandem breaker, you can cause big problems.
If you don't know what that means, please hire an electrician.
'66 SS Clone
Fast Burn 385hp Crate 350 (for now)
Muncie M20 & 3.42 Posi
UMI Stage 2 Suspension all around
bry66 is offline
post #4 of 25 (permalink) Old Feb 7th, 16, 6:38 PM Thread Starter
My thought was to get 2 tandems for the 20's 2 &3 down & the ones 7 & 8 to make room for a 20 a 240 breaker. Does that sound right?
77 Monte
post #5 of 25 (permalink) Old Feb 7th, 16, 7:16 PM
If you get the quad breaker that I linked to, it makes your job much easier. Then you don't have to relocate any wires. The two 15 amp circuits on the left side of the panel can stay where they are, with the 20 amp 2 pole in the middle of them.
post #6 of 25 (permalink) Old Feb 7th, 16, 7:20 PM
dan
What are the breakers supplying that you want to put on tandem breakers? You might be able to splice the wires together and land them under one breaker.
Dan5798 is offline
post #7 of 25 (permalink) Old Feb 7th, 16, 7:30 PM
dan
How far away from the panel is the hot water heater? It may need a local disconnect.
Dan5798 is offline
post #8 of 25 (permalink) Old Feb 7th, 16, 8:26 PM
Bryan
Do yourself a favor and bring in an electrician to upgrade your panel. You already have a few tandem breakers on a relatively small panel to begin with. A panel upgrade costs only a couple hundred bucks.
I am usually a big advocate of DIY when it come to home improvement projects, but if you don't know your way around an electrical panel then you have no business poking around in there.
One of those things where if you have to ask...
'66 SS Clone
bry66 is offline
post #9 of 25 (permalink) Old Feb 7th, 16, 8:34 PM
Rich
Do not go there...period.
haughty, 68-13427 and bry66 like this.
Rich
1967 El Camino (White)
1965 El Camino (Sold that junk)
HandOverFist is offline
post #10 of 25 (permalink) Old Feb 7th, 16, 8:52 PM Thread Starter
Kitchen plugs, basement plugs
Sump pump & garage
I don't think I'll double up.
Probably take 50 ft. run.
77 Monte
post #11 of 25 (permalink) Old Feb 7th, 16, 9:00 PM
It doesn't matter what is currently on the single pole breakers since replacing them with twin style doesn't change anything other than the space the breakers use.
A disconnect or not at the WH has nothing to do with making room in the panel for a double pole breaker.
The main thing is to get circuit breakers that are allowed in the panel according to the manufacture of the panel.
Read the label.
post #12 of 25 (permalink) Old Feb 7th, 16, 9:02 PM
Rich
Check the data tag on the heater. Most require 10-2 w/ground and a 30 amp dbl pole breaker.
Rich
post #13 of 25 (permalink) Old Feb 7th, 16, 9:38 PM
Not sure you want to hear this ... but IMHO your 100AMP panel needs and upgrade.... not only panel but also SERVICE up grade .. I would do a 200 amp 150 at the least....
Not sure where you live some townships are vary strict regarding service upgrade .... But most around me let you do it, but need a inspection ... b=4 the power CO installs the upgraded line to your mast drop.
Wayne
TC # 186
ACES#1556
WayneK is offline
post #14 of 25 (permalink) Old Feb 7th, 16, 9:43 PM
Rich
Not enough info to warrant that assumption.
Rich
post #15 of 25 (permalink) Old Feb 7th, 16, 9:44 PM
I am a Electrician. Juts know the amp rating of the W/H , then get a quad as sed earlier. What typ of breakers are they cause some are harder to find. I'm on my phone and can't see them. Out of curiosity what is the current W/H barker?
badtoad is offline
This Thread is more than 1291 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
