any boat people here? think of buying a 1984 SEA RAY CUDDY CABIN - Chevelle Tech
 22Likes
post #1 of 60 (permalink) Old Jul 6th, 20, 8:28 AM Thread Starter
Kris
Hey guys, our boat at our cottage sank a few years ago. What do you guys think of the ad below?
https://www.kijiji.ca/v-view-details...dId=1509479104
also this one..
https://www.kijiji.ca/v-view-details...dId=1507924702
13-1 compression 482 BBC (.125 bored over block filled)4 bolt main with good forged solid internals, square port heads, big solid roller camshaft ([email protected] intake/[email protected] ex .761 lift intake .707 exhaust 109 LSA),Weiand team G with 4150 flange, Holley model # 0-9380 850 cfm, 2 inch primary Hooker super comp headers with 12 inch collector extensions, TH-400 fully manual VB, Freakshow 4000 stall converter,4:10 gears
best time so far in the 1/8 May 18 2019 [email protected]
hear it running
MonteMan454 is offline
post #2 of 60 (permalink) Old Jul 6th, 20, 9:15 AM
Allen
Re: any boat people here? think of buying a 1984 SEA RAY CUDDY CABIN
Shame you're not closer as I've got a 24' Baja cuddy cabin (454/bravo) project that I'd be happy make someone a great deal on. I lost interest years ago and it's just been setting; now if I had a cottage on a lake then I sure I would have finished it :-)
I like the idea of a boat but not living by water anymore it should have stayed just an idea :-(
Good luck in your search, sounds like you have a great boat situation on your hands.
Blown1932 is online now
post #3 of 60 (permalink) Old Jul 6th, 20, 9:44 AM
the drivetrain in the second one with the cobra. Do not even entertain any boat with an OMC engine. I repeat. DO NOT!
Not sure what the flooring is in either but looks to be carpet glued to Plywood. Not a great combination if not stored properly. 10 years ago I owned a 86 sea ray. Nice boat but it had a fiberglass tub with snap in carpet and a mercruiser v8/alpha. Pretty simple to work on and pretty bulletproof. I've owned 2 sea Ray's and my current boat is a 86 Formula. You can get decent older boats but you need good bones and a drivetrain you can maintain and get parts for.
You either need a survey or at least someone very knowledgeable in boats to check the stringers and transom for rot. It doesn't matter how shiny the fiberglass is if the wood is rotted.
How did your boat sink? Let me guess, split bellows or not beingcovered in a rainstorm. I tend to like trailer queens. No bottom paint as they generally live a lot easier life. Also. Good pictures of the bilge says a LOT about a boat. Here is my Formula. All of my boats looked similar and sold quick when I sold them
67
70 (SOLD)
Alwhite00 is online now
post #4 of 60 (permalink) Old Jul 6th, 20, 10:25 AM Thread Starter
Kris
Thanks guys! Yes, too bad I am so far away from Colorado...it sounds like a great project. OK I will stay away from the OMC powered unit, I talked to the guy and he said it is SBC? He said it was rebuilt and bored over possibly a new cam..Did "OMC" buy SBCs and "convert" them to marine engines? The "Ciera OMC powered" also seems to have small leak and you cannot leave it in the water for week or so. He thinks it needs some more marine silocone around the end unit but who knows??
The Sea ray is a lot closer for us to look at. it is powered by a Mercruiser 140 3.0l. I phoned one boat repair place (for a pre sale inspection) and their schedule is packed. I will try another boat repair place, I don't know enough about boats to try it myself.
Yes, I guess the transom etc can be a weak point etc..
My Mom wants something for our cottage for her and grandkids/(my niece and nephew) to cruise on the river. I would like to take my son (when he is older) out on it as well.. It would be great if it sat 6 people and it has enough power to go tubing etc.. It would probably be my responsibility to take care of it as my Dad is getting too old. I would prefer something "turn key" as I have too many projects (trying to finish my tow rig for the drag car and actually racing)
Here are some pics of the last boat (at the cottage river) after the toronado of 2018 sank it,
Name:	boat sank 1 (Medium).jpg
ID:	632166   Click image for larger version
Name:	boat sank 2 (Medium).jpg
hear it running
post #5 of 60 (permalink) Old Jul 6th, 20, 10:31 AM
Mr Bill
Not sure why you would say that ? OMC engines and Mercruiser engines are exactly the same. They are all basically Chevy engines that came from GM.
I cant speak for the outdrives but as far as the engines there is no difference. I have 2 OMC 5.7's and 2 Mercruiser 5.7's in the shop right now and they ar identical.
Same deal with the 4 cylinders. The only oddball was actually the big Mercruiser 4 cylinder engine that was basically half of a 460 Ford.
OLDED likes this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #6 of 60 (permalink) Old Jul 6th, 20, 10:46 AM
It's not the small block Chevy that is the problem it is everything that is bolted to it and the outdrive. Do what you want but don't say I didn't warn you. They went out of business 20 years ago. Unless you want to become a OMC mechanic good luck finding a tech that specialized in a company that was out of business before they finished school. I do all of my own work and never have any trouble finding merc parts. Yes the OMC is a SB.
As far as needing more marine sealant. If that was the sellers "suggested fix" I weld run not walk away.
Boats are not cars, you cant just park them for a year or two and throw the family in and drive across the country.
How about a pontoon with a outboard?
Cam and pduncan like this.
67
70 (SOLD)
post #7 of 60 (permalink) Old Jul 6th, 20, 10:54 AM Thread Starter
Kris
Ah yes , so all the drive train after the OMC boat engines tend to fail..OK I will stay away! I guess a outboard engine generally be less maintenance than a "in board" ? For our old 70hp Johnson, I just changed the gear oil occasionally and when storing it put fogging oil down the cylinders...probably not enough but a inboard seems like more work
My sister suggested a pontoon boat as well, but they seem to be over $10,000 up here..maybe we should just try to get something similar to what we had before..
https://www.kijiji.ca/v-powerboat-mo...-ss/1509298466
hear it running
post #8 of 60 (permalink) Old Jul 6th, 20, 11:31 AM
I did not say they tend to fail. Please reread what I posted.
67
70 (SOLD)
post #9 of 60 (permalink) Old Jul 6th, 20, 11:51 AM
Jonathan
I have had a couple of boats. My current one is a 1996 Sunbird Corsa with a Volvo Penta 4.3L. PO replaced it with a later model 4.3L truck engine. He made mistakes and I have fixed the engine and it runs strong.
The bolt ons can be a problem but I have had no issues finding parts. My outdrive has been fine, it has been engine stuff that has given me the most trouble. Since mine is a trailer queen I have used mostly auto parts store stuff.
Exhaust Manifolds, impellers, carburation, distributer, etc are all marine based. I always use marine alternators and starters due to sparking
My boat sat all winter and Covid with Non-ethanol fuel and started just fine. In a way they are like cars, they do like to be used.
Two 72 Chevelle Malibus, both 350 2bbls one Placer Gold, one Midnight Bronze
Other cars:
2005 Pontiac Vibe
2005 Ford Excursion
2000 Dodge Durango
2003 Mercedes E320
2-2018 Ford Fusions
2013 Ford Fusion
Chevelle_Nut is offline
post #10 of 60 (permalink) Old Jul 6th, 20, 12:00 PM
Cam
Cameron Milne
It is the OMC stern drive units themselves. They cut a huge gaping hole in the transom so they can jack not the outdrive, but the entire engine and outdrive together. Mercruiser had a more rational approach and is still in business.
I love OMC outboards, everything that is except the FICHT outboards. They seemed like a great idea but leaned out and failed at part throttle. A combination of an industry downturn, the FICHT failures and warranty costs, all around the time of an acquisition frenzy sank the once unassailable OMC around 2001. Evinrudes by BRP now are radical and cool.
Sun Ray boats were made in Quebec. I actually worked with the daughter of the owner of Sun Ray. They were decent boats, though not award winners like say Jim Wynne for Crestliner.
Sea Rays are good boats, but whatever you get used is more about how well the boat was treated, maintained & stored. Watch for rot in the transom & stringers, jury-rigged electrical upgrades. Any propane appliances need to be checked before operating. Cables, outdrives. Remember that on the water cruising & top-end are like running on a dynomometer for an extended run. You need a capable engine that can take it.
Unless the boat was imported from Florida, Ontario is blessed with lots of fresh water which is good news for open cooling systems.
"The more you know,
TC Gold #120
Cam is online now
post #11 of 60 (permalink) Old Jul 6th, 20, 1:28 PM
Dig the hot chick with the big O 80’s glasses down in the cuddly cooking on the stove ..
67ss4spd is offline
post #12 of 60 (permalink) Old Jul 6th, 20, 1:53 PM
Dennis
I have a 1989 Sanger DX21 with an OMC outdrive. It’s the later “Cobra” drive that did not have the huge transom cutout. It’s been great since I bought it brand new in 1989. But when I do service it (myself) parts are getting harder to find and more expensive. We have kept this on a Hydro Hoist in a covered berth in fresh water since new.
My other boat, 1990 Tiara 3600 Open, has twin Mercruiser inboards based 454 Chevy engines. Parts are much more readily available and while expensive because they are for “marine” use, they are cheaper than the OMC parts. We keep this one in a covered berth in fresh water too but it’s not on a hoist.
And when I refer to “OMC” and “ Mercruiser” parts, I’m not talking about engine parts. It’s all the add on items.
I too would avoid OMC if I were looking for a boat but the main thing I would checkout is the floors, transom and stringers. IMO, a failure of any one of these renders a boat scrap yard material.
66 Chevelle hardtop - LFX 3.6 liter 4 Cam V6/6L50 6 speed auto trans, 3.07 10 bolt, full Hotchkis suspension, Wilwood 4 wheel discs, white with red interior, cowl hood.
67_LS1 is offline
post #13 of 60 (permalink) Old Jul 6th, 20, 1:57 PM Thread Starter
Kris
Thanks guys, I will continue researching.. Yes that brochure is awesome for the "Ciera"! Interesting about the FICHT technology..
(a) Ficht (ex OMC & now Bombardier) is a german invention where the fuel is
subjected to an impact shock (like dropping a stone into a full bucket of
water, the resultant pressure/shock waves overflow the bucket), the pressure
waves then get directly injected through a nozzle into the combustion chamber.
hear it running
post #14 of 60 (permalink) Old Jul 6th, 20, 2:49 PM
Jonathan
With the age of boat you are looking for are you wanting a water ready boat or a project? All boats are projects, even new ones. If you want a project try to find one with solid floors, starts and runs. Try to get a lake test on it too. NOTE: Don't make the mistake I made and bought one with 2 bent valves and blown head gaskets. Fortunately my lower end was undamaged.
Also, the RV and boat market are hot right now, boats are at a premium. People realize that social distancing is easy on a lake.
Other cars:
2005 Pontiac Vibe
2005 Ford Excursion
2000 Dodge Durango
2003 Mercedes E320
2-2018 Ford Fusions
2013 Ford Fusion
post #15 of 60 (permalink) Old Jul 6th, 20, 3:08 PM Thread Starter
Kris
Ah yes I was wondering why there aren't as many choices for boats on facebook marketplace etc..I am hoping for one ready to run, I think this one is running on the water already,,
The example above only seems to seat 4 where the other boats seat 6 at least..
maybe this one as well, it has a aluminum hull so perhaps that means there is less chance of rotting
https://www.kijiji.ca/v-powerboat-mo...3816?undefined
hear it running
