Engine Dyno Vs. Chassis Dyno - Chevelle Tech
 20Likes
post #1 of 18 (permalink) Old Apr 8th, 20, 5:43 PM Thread Starter
Here is a comparison between the two:
https://www.hotrod.com/articles/test...chassis-dynos/
My Chevelle w/ open headers:
1971-Chevelle is online now
post #2 of 18 (permalink) Old Apr 8th, 20, 5:58 PM
Re: Engine Dyno Vs. Chassis Dyno
Pretty good article. However the track does not lie.
jeff swisher and Kirk's67SS like this.
oldcutlass is online now
post #3 of 18 (permalink) Old Apr 8th, 20, 6:14 PM
. “All runs were on 91-octane unleaded "California" pump premium gas, corrected using the SAE J607 performance-industry standard factor (roughly equivalent to the old-school muscle car "gross horsepower" rating method, it generates numbers roughly 4-percent higher than SAE J1349 net hp, the rating method in use for late-mode”
The same correction Skip White Performance uses, gee imagine this ! Hahaha
Reelysalty is offline
post #4 of 18 (permalink) Old Apr 8th, 20, 6:30 PM
This is a good example of how intake and exhaust systems can kill a good engine. On the engine dyno the torque curve is flat from 3500 to 4700 and on the chassis dyno it shows decreasing torque. The breathing of the engine is badly affected by the in-car hardware.
So a good engine can be hurt by the choice of stuff in the car.
Derek69SS and jeff swisher like this.
JWagner is offline
post #5 of 18 (permalink) Old Apr 8th, 20, 7:28 PM
Allen
Originally Posted by Reelysalty View Post
. ďAll runs were on 91-octane unleaded "California" pump premium gas, corrected using the SAE J607 performance-industry standard factor (roughly equivalent to the old-school muscle car "gross horsepower" rating method, it generates numbers roughly 4-percent higher than SAE J1349 net hp, the rating method in use for late-modeĒ
Here we go again
77 cruiser and blue_69_malibu like this.
Blown1932 is offline
post #6 of 18 (permalink) Old Apr 9th, 20, 5:40 PM
Best final tuning device was never a dyno. Best development tool for new parts, systems is an engine/chassis dyno.
As oldcutlass said above, the BEST dyno is "The Seat Of The Pants" dyno, that is one where you go drive it, change it, and see if it helped.
Dave Ray is offline
post #7 of 18 (permalink) Old Apr 9th, 20, 8:47 PM
rick
The engine shop that assembled my balanced rotating assemble from Wolfplace has a new dyno and will spend an afternoon with me & my 489 for $500 or there's another shop local that has a chassis dyno for 3 pulls for $75 but no tuning that's extra, would I be wasting $500 with the engine dyno??
shovelrick is offline
post #8 of 18 (permalink) Old Apr 9th, 20, 8:54 PM
What is there to tune ?
post #9 of 18 (permalink) Old Apr 9th, 20, 9:10 PM
A carb and a distributor, most likely...........
Another stellar post.
77 cruiser likes this.
blue_69_malibu is offline
post #10 of 18 (permalink) Old Apr 9th, 20, 9:18 PM
Relative to either dyno, a track:
1) has changes in weather, temperature, humidity, etc. over the course of a day/evening
2) often has inconsistent prep work (ie - how much sticky stuff is down)
3) relies on the driver's ability to launch the car, change gears, etc
4) will give different MPH and ET for the same car based on how much fuel, water, driver weight, etc. is in/on the car at a given time
The track is more fun.....but the science, analysis, etc is all done better on a dyno.
The butt dyno is one of the worst measurements.....especially for the Kardashians.
It is exponentially easier to tune a carb and a distributor on a chasis dyno where everything that I've mentioned in points 1-4 has been eliminated.
For example, it's MUCH faster to change jets and other carb parts when actually getting an AFR reading from a computer.....then trying to figure why Pass A was better than Pass B, which wasn't as good as Pass C.
Money spent on a chasis dyno is some of the best money you'll ever spend in this sport/hobby....and a massive time saver.
67_LS1 and Derek69SS like this.
post #11 of 18 (permalink) Old Apr 9th, 20, 9:29 PM
I don't think you'd be wasting money. Then engine will be run in, check for oil leaks, plus you'll have a dyno sheet to showoff on TC.
blue_69_malibu and shovelrick like this.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is online now
post #12 of 18 (permalink) Old Apr 9th, 20, 9:34 PM
FWIW, I think going to the Chasis Dyno is a blast.
post #13 of 18 (permalink) Old Apr 9th, 20, 9:51 PM
It is. Listening to your engine on an engine dyno is a blast too.
blue_69_malibu likes this.
77 Monte
post #14 of 18 (permalink) Old Apr 10th, 20, 8:52 AM
Not at all. In addition to being cool as hell to watch and listen too, what I got from my dyno session was an initial run up, break in, check for knocks, leaks, timing, A/F mixture tuning (idle and throughout the RPM range at WOT), EGT, coolent temp, and a host of other things that they will (should) check as they go through it. The biggest benefit however is doing this before it goes in between the fenderwells.
Having never witnessed a dyno run in real life, and having the usual "nerves" at the first start up (i.e. "I hope I did everything right!"), the wildest part for me was hearing the dyno load down the engine on the first pull. It just sounds angry like the mechanical equivalent of a giant Clydesdale and 2000 lbs of muscle hunkering against a pulling harness. That engine just grunts for all it's worth until the dyno lets it climb through the pull. I had a great time.
Everything one would normally tune on an engine with the added benefit of seeing how it affects your power and torque.
-Kevin
1965 Chevy Biscayne
<removed> 454cid, "peanut ports", Voodoo 60201
<coming soon> 460cid, Brodix RRO 270, 229/241 Hydraulic Roller
TH400, 3.36 Stock Rearend
65cayne is offline
post #15 of 18 (permalink) Old Apr 10th, 20, 9:03 AM
rick
I'm probably going to do both then, the chassis dyno without them touching the motor is $75 for 3 pulls which IMO is cheap to find out the loss from the drive train, there's a local 1/8th mile strip that I haven't been on since the late 70's maybe early 80's I'm thinking of going there but everyone local says don't waste your time go to Bradenton 1/4 mi. track it's a much better track, John at the engine shop just had a new dyno installed about 2 months ago that gives more info than his old dyno, he said he needed a little time to get to know it so by the time I'm ready he should be familiar with it, if he's open for business
