How much does your car weigh - Page 2 - Chevelle Tech
 5Likes
post #16 of 20 (permalink) Old Dec 2nd, 19, 10:21 AM
Re: How much does your car weigh
1969 Beaumont
Small Block, aluminum heads, intake and rad
700R4, 12-bolt
All steel, full interior, no AC
Aluminum Wheels
3450 without driver.
1969 Beaumont
1977 Bronco
The rest are boring responsible adult vehicles not worth mentioning.
Chris27 is online now
post #17 of 20 (permalink) Old Dec 2nd, 19, 12:05 PM
Jon N.
Originally Posted by Billdini View Post
Here is a chart for all Chevelle's broken down by engine and body style. It also adds individual options
https://www.chevellestuff.net/1968/misc/dimensions.htm
The listed weight for a SS El Camino on the ChevelleStuff chart is wrong-wrong-wrong. Most likely they copied a small block weight. NHRA shows 3500 for a base SS 396 El Camino.
Just as an aside, I have never had any problem getting my stock class drag race cars under NHRA's listed shipping weight, sometimes way under. When I see other people listing what their cars weigh, I often wonder what they have secretly filled with lead.
Jon N.
dyno jonn is online now
post #18 of 20 (permalink) Old Dec 2nd, 19, 1:11 PM
Last time I corner scaled my 71, with the stock 12 bolt and conventional springs it weighed:
3806 lbs
2150 front
1656 rear
56.49/43.51%
71 Chevelle SS454
All steel
full interior
iron 454 with aluminum intake
T56 Magnum
QT SFI bellhousing
3.5" driveshaft
Aluminum rad
235 & 295 tires
Stainless steel Rick's tank
FULL tank of gas (22-23 gallons)
No driver
I've done quite a few weight savings on my car, and it is still a tank. I have found several things that are just really heavy. Steel bellhousing (31 lbs), T56 Magnum (approx 140 lbs), Stainless EFI gas tank (52 lbs), full tank of gas (~145 lbs), full 3" exhaust (86 lbs). Also one of the biggest fluctuations in weight can come from wheel/tire combo. Anyone running skinnies and bias ply slicks are saving TONS of weight. When I go to my drag tire setup (skinnies + 295/55 drag radials) I save about 69 lbs.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #19 of 20 (permalink) Old Dec 3rd, 19, 4:05 AM
My 72 weighed (minus me) 3440lbs on a truck scale with about 1/2 tank gas.
Since then I removed the AC suitcase and the condenser, went to a slightly lighter battery and finally a mini-starter.
According to my fish scale I used to weight the AC equipment, my calculation now says I'm at 3990 lbs.
Engine specs below. Aluminum Torque Thrust II's are probably helping too.
'72, 385 sbc, Voodoo roller, 219/227; .515/,530 lift; AFR 180cc Eliminators, RPM Air-Gap, 770 Avenger, TH350 trans, 12 bolt 3.42's, Eaton Posi, TCI 2000 stall, Pypes 2 1/2" X-pipe system w/Race Pro's
Vehicle weight: 3390 lbs
Autoengineer_ is offline
post #20 of 20 (permalink) Old Dec 3rd, 19, 5:50 AM
oooops. I meant 3390 lbs after the few weight reductions.
