Spent some time making my shop more geezer friendly today - Chevelle Tech
 22Likes
  • 11 Post By ZZ69chevelle
  • 4 Post By DUTCH MAX HEADWORK
  • 1 Post By ak 67SD
  • 2 Post By busterwivell
  • 1 Post By ZZ69chevelle
  • 2 Post By ZZ69chevelle
  • 1 Post By RealRed70
post #1 of 11 (permalink) Old Oct 21st, 19, 10:18 PM Thread Starter
I have a 12'x30' loft, and it's great for storage, but getting stuff up there is a royal pain in, well, everything. I just ain't got the strength I used to, and the thought of hauling heavy stuff up steps results in stuff being piled in corners all over the work area instead. I came up with a simple and cheap solution, and it works great. So far I just used it for a 42" mower deck, but it was effortless. Next up is an electric winch so I can lift from below. This is as useful as my lift table. struggling is for suckers. It's just a Harbor Freight truck bed crane. I have unistrut under the joists, and a steel plate up top with some angle, and bolted through the whole thing. It's more than adequate for my use. I won't be lifting anything over 350# with it. Getting old sucks, but I ain't ready to throw in the towel yet.
Steve R, LeoP, SS427Rick and 8 others like this.
ZZ69chevelle is offline
post #2 of 11 (permalink) Old Oct 21st, 19, 10:31 PM
Al
Re: Spent some time making my shop more geezer friendly today
Nice! I have an attic loft and you just gave me an idea so I don't have to head balance loads on a ladder anymore.
DUTCH MAX HEADWORK is offline
post #3 of 11 (permalink) Old Oct 22nd, 19, 12:55 AM
I use a gatorlift that I attached the two winch cables to a 3' x 5' wood platform with stirrups at each end... I can load all kinds of parts or materials into my attic with ease...
ak
ZZ69chevelle likes this.
ak 67SD is offline
post #4 of 11 (permalink) Old Oct 22nd, 19, 1:49 AM Thread Starter
I was looking at youtube videos of similar lifts, but I don't have enough clear space for that. Too many benches and tool boxes under my loft. That would be the ticket though. I guess I could get another 30' long I beam and add another 12'x30' of storage...
post #5 of 11 (permalink) Old Oct 22nd, 19, 10:31 AM
I agree about the getting old stuff. I used to be able to carry a transmission from my truck to the back of the shop. Now, I'd have to use my engine hoist and a dolly to move one.
the heckler and Kirk's67SS like this.
66 Malibu
busterwivell is offline
post #6 of 11 (permalink) Old Oct 22nd, 19, 8:07 PM
Great idea,will give it a try for mine.Thanks, Tom..
sstom66 is offline
post #7 of 11 (permalink) Old Oct 22nd, 19, 8:37 PM Thread Starter
Just in case anyone would be interested, this is how I mounted it. I have two pieces of unistrut running across three joists, (48" across.) I sandwiched in a 24" piece of 1-3/4 angle to help spread the load on the joist. Up top I made a mounting base that reaches the I beam, and that is on a piece of 1/8" thick 24x24" aluminum just for good measure. I don't know if it helps or not, but it already had a hole in the center. I figured most of the load will be pushing down on the beam in front, and pulling up on the rear unistrut from below. I used 5/8" bolts in the back, and 1/2" allthread in the front. My full weight (250#) doesn't even budge the thing. It's probably a good idea to keep it to one end instead of near the center too.
Kirk's67SS likes this.
post #8 of 11 (permalink) Old Oct 22nd, 19, 11:24 PM
The problem I see is the wood beam may crush and cause the bolts and all thread to loosen and allow the whole thing to loosen and twist causing it to fail with an extremely heavy load.
oldcutlass is online now
post #9 of 11 (permalink) Old Oct 22nd, 19, 11:57 PM
Jason
Nice I’m doing this tomorrow if I have time what a great idea thanks.
Jasons 69 Chevelle is offline
post #10 of 11 (permalink) Old Oct 24th, 19, 8:01 PM Thread Starter
Cranking a handle was too much work. I added a 120V HF winch to the boom, and all is well. This will be the typical use it sees. Stuff that isn't too heavy, but a royal pain to climb ladder steps with.
SS427Rick and Kirk's67SS like this.
post #11 of 11 (permalink) Old Oct 24th, 19, 8:10 PM
Work smarter, not harder.
68post likes this.
RealRed70 is offline
