Ford's Super Duty Powertrains... - Chevelle Tech
  • 1 Post By Robinls5
post #1 of 15 (permalink) Old Aug 1st, 19, 10:59 AM Thread Starter
They finally released the power figures on the new 7.3L gasoline engine - just slightly more powerful than the GM 6.6L. An interesting thing is that the new Power Stroke diesel is going to have forged steel pistons (not sure what the advantage is - maybe some engine builders can clarify for me).
https://www.motortrend.com/cars/ford...lling-details/
My Chevelle w/ open headers:
1971-Chevelle is offline
post #2 of 15 (permalink) Old Aug 1st, 19, 11:33 AM
Re: Ford's Super Duty Powertrains...
Steel pistons can handle a lot higher peak cylinder pressure and temps. The latest designs keep the mass in check, with all the benefits of the higher grade material.
John B
“It isn’t the enemy that ruined America. It’s good people who bent over and let the enemy in. If the coyote’s in your living room pissing on your couch, it’s not the coyote’s fault. It’s your fault for not shooting him.” Uncle Ted
Jblack is offline
post #3 of 15 (permalink) Old Aug 1st, 19, 11:47 AM
A lot of the towing guys on the RV forums didn't seem too impressed with the 7.3 power numbers. But power isn't everything.... the 7.3 was designed for mpg under load, and longevity/durability. It'll be interesting to see how those pan out.
bulb122 is offline
post #4 of 15 (permalink) Old Aug 1st, 19, 2:53 PM
One other aspect of a steel piston is that its heat transfer is less than aluminum and keeps heat in the chamber and not in the oil. That extra heat is a benefit for a Diesel. And the thermal expansion rates for steel would be less than many typical piston alloys, allowing or a tighter fit.
I had a chat with the chief engineer from a piston company and he oddly noted that the piston temperatures in a Detroit Diesel (2 stroke) were higher than the melting temperature of aluminum pistons.
JWagner is offline
post #5 of 15 (permalink) Old Aug 1st, 19, 4:45 PM
Jonathan
As a towing guy the diesel torque on grades is the true advantage over gassers.
I too am interested in seeing what the 7.3L can do.
Two 72 Chevelle Malibus, both 350 2bbls one Placer Gold, one Midnight Bronze
Other cars:
2005 Pontiac Vibe
2005 Ford Excursion
2000 Dodge Durango
2003 Mercedes E320
2-2018 Ford Fusions
2013 Ford Fusion
Chevelle_Nut is online now
post #6 of 15 (permalink) Old Aug 1st, 19, 4:57 PM
Ford just came out with the hp/tq number for their new pushrod 7.3 gasser.
430 hp @5500
475 tq @4000
Detuned in commercial chassis trucks 450-750 to:
350 hp
469 tq
Video:
fr8dog is offline
post #7 of 15 (permalink) Old Aug 1st, 19, 5:20 PM
I think those guys were comparing it to v10s in motorhomes, and other current gas engines. I think they expected numbers that would blow away current gas offerings and were dissapointed. But, the 7.3 wasn't designed to make diesel numbers. It was meant to be a more efficient gas option.
Diesel will always trump gas for outright towing power, but it's not for everyone. A good gasser can be sufficient for many, and efficiency can make them even better. Gas pickups weigh less, cost less, and in 3/4 tons, can have more payload capacity (and less towing capability)
'68 Chevelle 357, M22, 4.66
bulb122 is offline
post #8 of 15 (permalink) Old Aug 1st, 19, 5:50 PM
Fords V10 was inevitably not going to pass more restrictive emission regulations and has had some issues dropping valves, in as little as 60k miles. They weren’t very powerful and are very thirsty. The gas motor option can be a great option for those not looking for monster towing capacity but want increased payload, such a slide in camper types.
As long as ford doesn’t go crazy on the 7.3 gasser price ,as an optional engine, and the 7.3 can muster acceptable mpg towing, I think it could sell well. I do have to admit that ford engineers paid homage to GM’s LS design,(have you seen pics of the new 7.3 and how similar it looks to an LS?), on their new “pushrod” big block. Many thought the 460 LIMA motor was going to be fords last pushrod ohv big block?
Video:
fr8dog is offline
post #9 of 15 (permalink) Old Aug 1st, 19, 9:48 PM
leo
Hence the oil cooling spray underneath the crown of that piston!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #10 of 15 (permalink) Old Aug 2nd, 19, 7:34 AM
Our OP2 stroke sees crown temps in the 500-520 C range. We are also running in the 200-240Bar PCP range as well. We've tested 4140, Inconel, and tool steel variants for our crowns. Also applying TBC's to keep the heat in check. Gallery cooling is our only means of cooling and we run 3 gpm of oil under each piston. We've seen oxidation on our pistons so you know we are running hot!
John B
Jblack is offline
post #11 of 15 (permalink) Old Aug 2nd, 19, 11:37 AM
Ron
Inconel? An Inconel piston? Bring money...what did you wind up using? And 3 GPM? That's quite a pump..seperate cooler for oil coming off the pistons?
My car is here:
bikeron is offline
post #12 of 15 (permalink) Old Aug 7th, 19, 11:44 AM
I do know. My buddy has a large truck shop. He is praying FORD keeps building the POWER STROKE. If they stop building the STROKER he will have to lay off some people.
How about , " LIFTING " the cab OFF to change the exhaust pipe that goes down directly dead center on the back of the engine and over the bellhousing.
My friends please remember
SPEED KILLS............. DRIVE A FORD
YOU WILL LIVE FOREVER
davewho1 likes this.
Robinls5 is offline
post #13 of 15 (permalink) Old Aug 7th, 19, 12:33 PM
Well Calvin doesn't like em either.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #14 of 15 (permalink) Old Aug 8th, 19, 8:55 PM
Jonathan
You don't have to pull the cab for the up-pipe. Remove the turbo, unbolt the pipe from the manifolds and exhaust, remove pipe. In fact the Powerstroke is designed to come out the front of the truck, techs just found that it was easier to pull the cab.
Powerstrokes are so popular that is why there are a lot of shops. My trouble free 166,000 mile 6.0L yes, 6.0L is an awesome machine.
Other cars:
2005 Pontiac Vibe
2005 Ford Excursion
2000 Dodge Durango
2003 Mercedes E320
2-2018 Ford Fusions
2013 Ford Fusion
post #15 of 15 (permalink) Old Aug 9th, 19, 11:56 PM
Remember the Power Stroke is the new term. The Original Diesel in a Ford pick/up was a........... ??? The International Diesel, That was a Gem!...
Robinls5 is offline
