Painting Idea, House Not Car - Chevelle Tech
 12Likes
post #1 of 30 (permalink) Old May 10th, 19, 1:32 PM Thread Starter
blm
So I am planning on painting the Aluminum siding on my house. Have ordered a 32 ft ladder and a ladder stabilizer (link below). Got a couple areas as high as 27 ft off the ground.
So as I am trying to think this out I began to wonder what to do with the paint container, roller and brushes while I am up at my working height. Most I have seen have suggested hanging a paint bucket via a hook off of the ladder or the stabilizer. Seems to me that the hook itself would complicate getting the paint out of the container as it would come to rest directly over the center of the container or there is one that hangs off the side of the ladder.
Well I got to thinking why not cut a piece of thin plywood (1/4 or 3/8) that conforms to the stabilizer and just wire it to the top of the stabilizer which would basically give me a platform (approx 40 inch x 10 inch) to set all my stuff on that is right in front of me. I believe the stabilizer can range from 30 inch wide to 65 inch wide and is 12 inches deep. HAve not seen this mentioned anywhere. Did someone just not think of this or is there a flaw in my plan?
https://www.zoro.com/werner-stabiliz...7p/i/G7469104/
blm is online now
post #2 of 30 (permalink) Old May 10th, 19, 1:59 PM
bob
Re: Painting Idea, House Not Car
I would brush the siding with a good Prudy 3" or 4" brush out of a 1 gallon with the rim cut out. I like the Nylox sprig or swan brush for latex paint. As for the paint hook this is what you need. You hang it on the rung of the ladder so the pot hangs of the side, this will leave a lot of room for your brush.
https://www.lowes.com/pd/Warner-Pain...ook/1000024757
https://www.purdy.com/products/brushes/nylox
bobm67 is offline
post #3 of 30 (permalink) Old May 10th, 19, 2:26 PM
Terry
$77 for the stablizer? This ones cheaper https://www.homedepot.com/p/Werner-U...AC96/100658403
TerryAT is online now
post #4 of 30 (permalink) Old May 10th, 19, 2:39 PM Thread Starter
blm
Yes it is cheaper but it won't span a window with a shutter on either side, which I will need that capability. Also the more expensive stabilizer has a 12 inch standoff and the above is only 10 inch. Which would make painting soffit which is 25 feet up a little easier.
I will definately need some brushes but was thinking a 4 or 6 inch roller would be faster/ easier to paint all the flat portions of the siding. Is that not so?
Also I am purchasing the main color in 5 gallon container, so would the one gallon plastic buckets be the way to go?
blm is online now
post #5 of 30 (permalink) Old May 10th, 19, 5:01 PM
Levon
Wink Re: Painting Idea, House Not Car
Brad you are braver than me.
I wouldn't think twice about hiring a painting company
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis, Ab. Canada
My Showroom
LevonH is offline
post #6 of 30 (permalink) Old May 10th, 19, 5:18 PM
Terry
How are you going to have a paint tray for a roller up on a ladder? You can only use a brush with the paint bucket hanging on the ladder.
post #7 of 30 (permalink) Old May 10th, 19, 5:30 PM
Terry
I dont like this idea. First of all your 32 ft ladder extended up to 27 feet will be a little bouncey with the smallest movements up there. I definetly wouldnt want to be fussing around with both hands either. One hand would always be holding the ladder. Maybe if I were way lower, I might try your "table" idea, but not at the top.
post #8 of 30 (permalink) Old May 10th, 19, 6:16 PM
Have you considered renting a man lift. You could knock out all the higher stuff with it and get the lower after you return it. It cost me around $300 for a weekend.
von and pnugene like this.
Ed C.
70 SS L34 Auto project
57 Belair hardtop project
Always looking
EdCarpenter is offline
post #9 of 30 (permalink) Old May 10th, 19, 8:52 PM
jerry
That's the only way I'd do it. While you're at it, rent a pressure washer and take care of all your high work.
pnugene likes this.
cheveslakr is offline
post #10 of 30 (permalink) Old May 10th, 19, 11:53 PM
Randy
^^Maybe it's my advanced age, but I'm not hanging off any ladder that high trying to paint. Man-lift is much safer and the platform solves the bucket issue.
^^I have a lift reserved for next week to pressure wash the Alabama mold off the north side of the house. JoMax and bleach solution in a garden sprayer loosens the crud, PW rinses it all off.
Randy
TC # 5401
67 Project SS Clone
pnugene is online now
post #11 of 30 (permalink) Old May 11th, 19, 1:02 AM
Me neither...does not take much of a fall to cause permanent disabling injury. 20 feet up might as well be stratosphere IMO.
JJ'65 is offline
post #12 of 30 (permalink) Old May 11th, 19, 1:55 AM
I like to use the 2-gallon buckets with a 7" roller and frame... But I have never seen those at my Home Depot or Lowe's (the roller, covers, and screen), just dedicated paint stores like Kelly Moore or Sherwin Williams... The 2 gallon buckets are carried at HD and Lowes. A 6" roller will be tight with the 1 gallon... Of course, I only put about 1 gallon in the 2-gal bucket, leaves room for sloshing, etc...
Personally, I'd roll out a small section, and then "lay it off" with the brush, also getting any areas missed by the roller, and then brushing any drips...
TC #1366
'70 Chevelle 427 Stroker Sold
'66 Convertible Sold
Dual Quad 396 & Conv Int
'66 SS L78
1966_L78 is offline
post #13 of 30 (permalink) Old May 11th, 19, 2:04 AM
Use a 2-gallon bucket with a roller and screen, no "tray" needed... its faster than using a tray too...
Here's a good video showing the technique
Hanging the bucket would make it a bit more difficult, but probably still doable...
TC #1366
'66 SS L78
1966_L78 is offline
post #14 of 30 (permalink) Old May 11th, 19, 8:47 AM Thread Starter
blm
I considered renting a lift. But they are $400.00 a day for an engine/diesel powered lift. However there are several drawbacks to a lift. First is how to get it from the rental to the job, I have a 4 cyl Tacoma with no hitch. Second is they are jerky when operating. We have them at work so I know this first hand. Also what happens when it starts raining 2 hours after you rent the lift. Dont think they are going to refund your money because it rained.
Decided a ladder was the way to go. I have also acquired a stabilizer and a ladder leveler.
It is true it is possible to fall and become injured but with proper use and a little common sense it is perfectly safe. Autombiles, power saws, electricity, guns, lawnmowers, chemicals are all dangerous and even fatal when used carelessly but are used without any harmful effects daily by millions and then there are those that are hurt daily by these items and many others. Take precautions and pay attention and ladders are no more dangerous than any other tool.
blm is online now
post #15 of 30 (permalink) Old May 11th, 19, 10:06 AM
SFD
You want the tow behind. It’s light enough to move by hand in the back yard or use a ride on mower to move it. Sunbelt rentals - usually one nearby.
SFD is offline
A girl and her car: The Story of CRN 631 Brother Bill Projects & Builds 39 Apr 23rd, 19 5:52 PM
New(sort of) member from Ga. CorvZ061 New Member Introductions 2 Dec 10th, 15 7:21 PM
Power Tour Car? LS swap? Need ideas 64tempestwagon LSx Engine 13 Nov 29th, 15 11:55 PM
Stolen 70 Chevelle.......Recovered 6t7chevelleSS Bench Racing 17 Apr 28th, 14 11:17 AM
How to buy a car from out of state? FlameOut Misc (NON CHEVELLE AUTOMOTIVE TECH) 14 Jul 11th, 13 4:48 PM
