Don't EVER want to hear any gripes about changing valve cover gaskets - Chevelle Tech
 30Likes
post #1 of 22 (permalink) Old Mar 23rd, 19, 9:57 PM Thread Starter
Rich
Because this is what I had to go through to change the valve cover gasket on the wife's car. I put new o-rings on the injectors while I was in there since I hope they will never see the light of day again while we own it. The timing chain was a tight as a drum which is amazing given that this thing has 224k on it.
ID:	589946   Click image for larger version
427L88, Pat_McNeil and BossHogg69 like this.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #2 of 22 (permalink) Old Mar 23rd, 19, 10:44 PM
Don
Re: Don't EVER want to hear any gripes about changing valve cover gask
Yep. Looks like a typical day at the Euro shop that I work at now. Been turning wrenches for over 30 years but the last 2 at this shop seen some interesting "engineering".
Don
Volks is offline
post #3 of 22 (permalink) Old Mar 23rd, 19, 11:09 PM
Cam
Cameron Milne
Yesterday. My D.D had to go through that to change a burned-out Xenon bulb. Crazy & not cheap. Timing chain should be changed now, plus stabilizer bar link has slop (way too many potholes around right now). Wifey saw the estimate $$$ (I didn't intend for her to see it) and next thing you know we are looking at new cars. I really like what I already have. I tried to explain that car maintenance expense still pales by comparison to new car payments.
427L88, LeoP, busterwivell and 4 others like this.
"The more you know,
TC Gold #120
Cam is offline
post #4 of 22 (permalink) Old Mar 23rd, 19, 11:17 PM
leo
I was just gonna say, wait til you have to change one of those headlight assemblies, same stuff almost has to be removed from the front of the car!!
Jeff65SS likes this.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #5 of 22 (permalink) Old Mar 24th, 19, 1:25 AM
Terry
It seems like these cars need the one piece fiberglass front ends that can come off more easily. lol
SSJohn likes this.
TerryAT is offline
post #6 of 22 (permalink) Old Mar 24th, 19, 8:55 AM
Kim
Had to do the same thing to change the alternator on my sons Mini Cooper.
Not real difficult just a bunch of stuff to remove and replace.
Kim
Kim57 is offline
post #7 of 22 (permalink) Old Mar 24th, 19, 10:05 AM
Cody
I had to do the timing chain on one of those, dislocated a rib getting the transmission snaked out from the subframe. To do the water pump you have to disconnect everything and slide the engine over to get room. It's almost easier to pull the entire engine and transaxle out to do anything!
Blackhawk is offline
post #8 of 22 (permalink) Old Mar 24th, 19, 10:34 AM Thread Starter
Rich
While this car is a blast with the 2.8L V6 (well, technically a W6), this car just doesn't package the 6 very well. The 4 would be much easier to work on. Heck, I'd have to tear it apart this far just to change the alternator. I had to tear it down this far, and a little more, to change the radiator last fall. I had to tear the bumper off to swap out the headlights! But, to be fair, the bumper cover comes off and on easily enough.
The good news is, even after 16 years and 224k miles every bolt came out without any issues each time, no corrosion anywhere that caused a problem.
LeoP and jeff swisher like this.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #9 of 22 (permalink) Old Mar 24th, 19, 10:38 AM Thread Starter
Rich
BTW, Volkswagen calls this the "service position". At a VW shop just getting it into and out of "service position" is about $800-$1000, not counting the work that needs to be done once you get it there.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #10 of 22 (permalink) Old Mar 24th, 19, 10:41 AM
Jesse
I feel for you, put timing belt, WP, t stat, plugs and new VC gaskets on my 03 CTS in December. Damn plastic vc's leak a little when it's really cold out. Looks like I have to pull front wheel and inner well to change turn signal bulb.
Jesse
6426yy is offline
post #11 of 22 (permalink) Old Mar 24th, 19, 10:48 AM
Tom Lloyd
Originally Posted by Rich-L79 View Post
BTW, Volkswagen calls this the "service position". .
I don't think its the car they are referring to when they say "Service Position"
Changed the electric water pump on my Wife's BMW, similar story but not as much panel removal.
Jeff65SS and davewho1 like this.
Tom Lloyd
take my advice, I'm not using it.
floyd66 is offline
post #12 of 22 (permalink) Old Mar 24th, 19, 10:51 AM Thread Starter
Rich
It was similar when I helped my brother change the headlight assemblies on his Avalanche. It would be near impossible to change some of the bulbs in there without pulling the headlight assembly out first and to do that you have to remove the grill and other smaller pieces. Ridiculous. My old 85 MR2 was easier to work on and it was a very tightly packaged little machine.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #13 of 22 (permalink) Old Mar 24th, 19, 11:46 AM
Cam
Cameron Milne
VS.
427L88, Chevello, LeoP and 5 others like this.
"The more you know,
TC Gold #120
Cam is offline
post #14 of 22 (permalink) Old Mar 24th, 19, 12:13 PM
To Rich.....my condolences.
Even getting at the oil filter on our '12 Buick Enclave is a pain. It's in front of the radiator. You almost have to be a contortionist with skinny arms and small hands to get it done. Only accessible from the top. Keep the Bandaids handy.
When I works, I works hard.
When I sits, I sits loose.
augy is offline
post #15 of 22 (permalink) Old Mar 25th, 19, 5:52 PM
Just like working on a Duramax or any V8 deisel . What a fiasco and to think the dealers are rushing techs to get those jobs done .
72 Malibu Family Fun Car
Seven2bu is offline
This Thread is more than 431 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Proper PCV valve setup in a 383 Stroker Sk8Crash69 Engine 14 Jul 9th, 19 4:01 AM
PCV in left valve cover, do I need breather in the right? Dan Orgill Engine 14 Jun 2nd, 16 7:27 PM
Valve covers, gaskets, plug wires devdakdrew Engine 6 May 24th, 16 2:49 AM
Valve Covers & gaskets 1967 chevelle Engine 6 Oct 12th, 14 2:26 AM
BBC tall valve covers with a/c or shaft rockers with a stock cover chrisx66 Performance 1 Jan 28th, 14 7:30 PM
