Install daytime running lights on '67 Chevelle? - Page 2 - Chevelle Tech
 5Likes
post #16 of 18 (permalink) Old Feb 28th, 19, 2:56 PM
Re: Install daytime running lights on '67 Chevelle?
Sure it is, take it out the front of the hole. You need a tool that catches those notices, or rubber grips to undo the bezel. Or am I thinking the ignition switch?
post #17 of 18 (permalink) Old Feb 28th, 19, 3:40 PM
David
Originally Posted by darksky View Post
That looks like a good product. However on a '67 Chevelle, it's not easy to get to the back of the headlight switch to change the wiring connections. Thanks for the link though.
Nor so on a 72, which is why I haven't installed it yet. But I have some heat/ac control issues to deal with, an occasional loose ground somewhere that affects the instruments, and plan to switch out all my dash lights to LED's...so, a project
I did purchase and install his intermittent wiper switch mod which turned out very well.
davidaugust is offline
post #18 of 18 (permalink) Old Mar 1st, 19, 9:07 AM
All the factory does to get DRLs is run the high beams in series. Instead of each filament having 12v and ground, they share connections through relays, one lead of one bulb will have 12v, the other lead will be tied to the other bulb lead, then the last unused lead goes to ground. Both high beam bulbs are sharing 12v, so each bulb will get 6v. That's why they look yellow.
(headlight bulbs are non-directional, so there is no polarity (+ or -), you can hook them up however you choose without messing the bulb up.
Normal:
............Driver......................Passenger. ....................
12v---- +bulb- ----gnd 12v---- +bulb- ----gnd
DRL:
............Driver...........Passenger............ .....................
12v----- +bulb- ------- +bulb- ------gnd
You can wire the bulbs up with jumper wires and test it out to see if you like the look before you commit.
I know it's pretty confusing, but hope this helps?
NickeyChevelle likes this.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
1969 Chevelle SS396 Convertible Time Capsule KenFichtner Tag Team 31 Sep 30th, 19 8:35 PM
65 Chevelle SS dash lights/ gauges MalibuSeaS Restoration Corner 22 Feb 10th, 19 4:49 PM
1970 Chevelle Legend700 5 Speed Install Info JodysTransmissions Transmission & Driveline 26 Jun 14th, 15 2:34 PM
running lights dlll Electrical & Wiring 2 Dec 9th, 14 10:31 AM
1964 Chevelle - Turn signal indicators on when head lights on - help mtbyrd Electrical & Wiring 6 Dec 22nd, 13 9:12 PM
