Set saw at 33 1/2. I think. Might have to run out to the shop.> A square corner 90* saw sets at 45*
You are a long way from 90*. Think 180 degrees, subtract 133*, you got 67, 1/2 of 67 is 33 1/2
You are thinking too hard.
If corner was 45* the cuts would be 22 1/2*
I cant tell from the pic and probably am not the best teacher. What I would do is take some scrap wood and lay it seperatley against the wall and mark the angle as it crosses. Go the miter saw and match angle to pencil line. Then do the same on the other wall and fit the 2 pieces of scrap and adjust if needed. Sometimes angles in carpentry are not clear as day and take a bit of trial and error. That is how I would do it IF 22.5 or 33.5 didn't seem to work. Scrap wood and scribe lines will save good wood. Good luck, hope it makes sense as described.
I never looked at the second pic with close up numbers - 180* minus yer 133 is 47 so half dat, 23.5*, wall does look 45 ish. Start there, it’s wood, cut two 12” test fit pieces, left and right of the same degree miter and test fit..don’t forget a true craftsman copes the inside corners..
33.5.
someone mentioned coping the inside corners, which way does the teeth cut on a coping saw, push or pull?. One of the 3 parts of a test I give new carpenter prospects.
Shat, 180 minus 133 ain't 67 it is 47. half of 47 is 23 1/2 is the cut. I have a photographic memory but the flash is burned out.
33.5.
Since I'm self taught but good enough to get high end work I'll give the coping saw question an answer. I know I have tried both ways, but I find pulling to work better. It does seem to rip the finished wood a bit, so pushing is probably the correct answer as I think about the process. When in doubt, hope for paint and wood in a tube vs perfection and stain.....
Coping saws were made to cut on the pull, you will not fuzz the wood if you cut to just where the face of the trim meets the cut.
I had men that used the saw both ways, you will break the blade cutting on the push if not careful.
Taking up an extension cord and building a set of saw horses is the other 2 parts of the test. Had one fellow that took a half day to build a set and another one put a set together in a room with a 32 inch door, he had to take them apart to get them out of the room.
Remember a carpenter marks once, half assed carpenter marks twice and and a d@^^ fool just keeps on marking.>
Good thing I have saw horses ready. I prefer the metal ones that fold and store...all I need to do is replace sacrificial wood when time comes. Lowes used to have good ones, but been years since I had to get new ones so never know if quality has changed.
Related Threads
Team Chevelle
5.1M posts
115.9K members
Since 1998
