Air Compressor Blues... - Page 2 - Chevelle Tech
 26Likes
post #16 of 74 (permalink) Old Nov 5th, 18, 8:06 PM Thread Starter
Re: Air Compressor Blues...
Originally Posted by 71350SS View Post
Here you go is this what you are looking for ?
https://sandiego.craigslist.org/nsd/...729652479.html
sometimes you can find a gem on the local craigslist if you aren't in a hurry to buy one.Although this one is probably too far away for your needs.
I think that one may be even older than mine - either that, or someone put a completely different compressor on the tank. I have checked Craigslist locally and there are several setup like mine, but every single one of them has pinholes in the tank (several different brands).
My Chevelle w/ open headers:
WakkoWarner is offline
post #17 of 74 (permalink) Old Nov 5th, 18, 9:08 PM
jeff
For $7 you can JB weld the pin holes worst thing that would happen is you will get another hole..You got that now.
Best thing that could happen is the fix gets you another year or more while you search for a tank.
I passed up 2 tanks at local auctions one was a portable 20 gallon and the other was a 5 gallon.
5 bucks each. I have portable tanks and have stuck them onto things like yours.
Maybe you can find a newer oil less compressor that is shot with a good tank. If you are not into Epoxy fixes.
shovelrick likes this.
jeff swisher is offline
post #18 of 74 (permalink) Old Nov 5th, 18, 11:52 PM
billy
Originally Posted by jeff swisher View Post
My father-in-law has the same one as does a friend that sold me my 47 dodge truck. Both tanks leaked.
I have fixed leaking tanks with Original JB weld.
Sand the area with 80 grit sand paper and clean with acetone or lacquer thinner and paper towels.
Make sure no moisture or oil is present.
Now mix up the JB weld and let it set for a few minutes and then mix it again.
I may over kill on the 2X mixing but it is what I do.
Now spread it onto the place to be patched.
I have used masking tape to hold it in place or keep it from saging.
That may just save your tank.
I used it on fuel tanks also and never had a leak and I ran MTBE TEL toluene and other things in my tank never an issue.
DO NOT use JB quick
I have never seen an air tank come apart they always develop a leak and fizzle out like a dud firecracker. Path of least resistance.
i had a neighbor his 3 yr old son walked by a POS Craftsman Air Compressor very similar to the ops time bomb . The tank exploded maiming the child severely and I mean severely ! it amazes me so many are ignorant to the fact these things will explode and should be inspected , my guess its just something most people are really unaware of happening ! I change my tank every eight years and not with some old rotted tank or patch welding a rusted out tank . A decent new compressor is starting at what 400 bucks ! IMO the OP has escaped a bullet with that time bomb and better off going to the orange box a picking up a nice new compressor
b&b's69 is offline
post #19 of 74 (permalink) Old Nov 6th, 18, 6:33 AM
jeff
Never seen it happen. But I suppose it does happen as you have stated.
Yep If it is a danger by all means spend now and avoid the above. Would be money well spent.
Mine is under the steel work bench with 3/4 plywood hiding it and only a hole in the plywood for the fan to get air.
Mine is not portable though.
b&b's69 likes this.
post #20 of 74 (permalink) Old Nov 6th, 18, 8:06 AM
billy
the accident changed my thinking about air compressors and their safety ! it took years before the child was able to walk again ! iMO ts just not worth the slightest chance of something failing causing tragedy
b&b's69 is offline
post #21 of 74 (permalink) Old Nov 6th, 18, 8:26 AM
rick
I've never seen or heard about one blowing up but I could imagine the metal pieces going like a grenade, I'd replace the tank with a new one, the motor & pump might last longer than a new one, they don't make them like that anymore, I bought an '87 CH 5 hp 60 gal for $125 a few years ago, take a chance on a used 1 or buy new
shovelrick is offline
post #22 of 74 (permalink) Old Nov 6th, 18, 10:44 AM
Dwight
One of those self tapping sheet metal screws with a rubber washer fixed mine up the other day. It is in the far back corner of the shop so not really worried about it blowing up. I suppose it could happen though.
SeventyLS5 is offline
post #23 of 74 (permalink) Old Nov 6th, 18, 11:16 AM Thread Starter
Here are a couple that I am considering. The Porter Cable will be less than $400 with tax (2 year warranty) and the California Air Tools unit will be about $415 with tax (1 year warranty). Let me know what you think:
https://www.tractorsupply.com/tsc/pr...r?cm_vc=-10005
https://www.homedepot.com/p/Californ...020C/205773204
post #24 of 74 (permalink) Old Nov 6th, 18, 11:58 AM
Ron
https://www.about-air-compressors.co...mpressor-.html
Yep, they go boom!
You might contact these people:
https://www.compressorworld.com/air-tanks
b&b's69 likes this.
My car is here:
bikeron is offline
post #25 of 74 (permalink) Old Nov 6th, 18, 12:29 PM
Wow. That tank ripped open on a nearly perfect straight line. Makes me wonder if that was the welded seam in the tank. Depending on heat affected zones and such, a weld can corrode faster than the metal adjacent to it.
JWagner is offline
post #26 of 74 (permalink) Old Nov 6th, 18, 1:39 PM
Pressure vessels like these are not repairable. Do everyone a favor and do the right thing and get rid of it / destroy it.
I can't hardly express in words how dangerous it is to attempt a at home repair. Yes, these are made to fail in a predicable manner,but when you start modifying or repairing them you can create a potential bomb.
Please don't attempt repairs.
Emsea is offline
post #27 of 74 (permalink) Old Nov 6th, 18, 1:41 PM
Terry
I think it rip right down the seam. Wonder if the regulator/shut off valve was working properly or it just kept on pumping air until it burst?
TerryAT is online now
post #28 of 74 (permalink) Old Nov 6th, 18, 1:45 PM
Terry
Im thinking its time to make a scatter shield blanket to wrap our tanks in!
The tanks should at least have some type rust proof applied to the bottom ,inside surfaces
71350SS and b&b's69 like this.
post #29 of 74 (permalink) Old Nov 6th, 18, 2:34 PM
Arno
Do not try to repair the tank.Buy a cheap china s??? compessor from a discounter,take the new tank and mount your compressor without the tank on top.It will be portable and the new tank should be good another 15 years...
Over here,they sell complete china compressors for under 150 $-the motor /switch and Valves are always junk-the tank is never the problem...
Arno
Oldcarsnbikes is offline
post #30 of 74 (permalink) Old Nov 6th, 18, 3:06 PM
Well if the inside was coated with something to stop the rust the compressor companies would make their product last longer and thus sell less products.
So someone needs to come up with a product that can be applied to the insides of a brand new compressor tank to stop the rust from starting at all cause we all know that a company's bottom line is worth more than our safety right ?
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
