Joys of changing a starter - Chevelle Tech
 8Likes
post #1 of 25 (permalink) Old Aug 1st, 18, 11:59 AM Thread Starter
I found this video of changing a Honda starter. It reminds me of the fact that guys who design cars are not likely to have any experience repairing them. This guy's experience is similar to what I found on changing the starter in my 4WD S10 Blazer. When I got about half the car disassembled, a mechanic friend of mine told the easy way to do it: disassemble the starter into pieces and drop out the pieces. Then get the mini-starter that goes in without any drama. Sure wish I had known that before doing the job. Anyway, here is 3 minutes of Honda fun.
JWagner is offline
post #2 of 25 (permalink) Old Aug 1st, 18, 12:07 PM
Re: Joys of changing a starter
Some Toyotas have the starter in the "v" underneath the intake. Obviously a tech didn't design that, but to be fair to the engineers- I've never heard of one needing replacement. As a former Honda tech I can't remember ever replacing a starter on a Honda with under 150,000 miles. As far as car companies are concerned, if you get 10 years or 100,000 miles out of a part they over-engineered it.
davewho1 and mino65 like this.
70 Camino...Roller
Tommy the Cat is offline
post #3 of 25 (permalink) Old Aug 1st, 18, 2:39 PM
I can see a starter being hard to change as it's not regular maintenance. Not a priority for the engineers. The ones I don't get are the regular maintenance items that are not made easy. My sister had a 1996ish Ford Contour. I changed oil on it for her. The filter is at the back of the engine mounted upside down above the transmission. As soon as you get the filter loose, oil dumps everywhere. Whoever designed that obviously has never changed their own oil before.
davewho1 likes this.
1969 Beaumont
1977 Bronco
The rest are boring responsible adult vehicles not worth mentioning.
Chris27 is offline
post #4 of 25 (permalink) Old Aug 1st, 18, 2:55 PM
rick
I had a 76 T/A with a 400 in the 80's and was changing my first set of plugs on the car and couldn't get to 1 of the plugs, called a mechanic friend and he said pull the pas side front wheel off and get at it that way lol it worked out fine but I don't think I would have thought about that back then haha
shovelrick is offline
post #5 of 25 (permalink) Old Aug 1st, 18, 2:55 PM
Anyone who buy's an Import deserves to have to work on it.
'66 SS Chevelle
91 octane special
first day out
[email protected]
Stokerboats is online now
post #6 of 25 (permalink) Old Aug 1st, 18, 4:14 PM
Because a Cadillac Northstar doesn't have the starter where the camshaft should be?!
None of the manufacturers are blameless in idiotic designs.
mino65 and 71350SS like this.
`You can't beat City Hall, but you can piss on the steps."
jpete is offline
post #7 of 25 (permalink) Old Aug 1st, 18, 4:39 PM
I had a 2003 Honda Element. Fortunately, I never had to have the starter replaced.
They were manufactured in East Liberty, Ohio.
goatless is online now
post #8 of 25 (permalink) Old Aug 1st, 18, 5:21 PM
rick
Designed & engineered by ??? is what the problem is, also they don't want owners doing their own repairs IMO, dealer needs that vehicle to come back for repairs so they can stick it to ya some more lol
post #9 of 25 (permalink) Old Aug 1st, 18, 6:20 PM
I had to do an alternator in a Tercel one time. Wide open engine bay. Figured I'd be done in half an hour. I couldn't find any way to turn the thing that wouldn't hit something. The firewall, intake, master cylinder, strut tower.
Turns out, you have to drop the CV shaft and pull it out that way!!
jpete is offline
post #10 of 25 (permalink) Old Aug 1st, 18, 6:48 PM
terry
The absolute worst starter I have had to deal with was on a Chevette...
mytmouz is online now
post #11 of 25 (permalink) Old Aug 1st, 18, 7:04 PM
Andy
I can do an Element/CRV in under an hour. A Toyota V8? Not so much. Nissan V8s are fun, but Northstar is a twenty minute job.
Worst starter ever? 79 Chevette, with power brakes, pre Gearwrench.
Andy's Auto Repair is offline
post #12 of 25 (permalink) Old Aug 1st, 18, 7:29 PM
Stan
Most new vehicles are designed and engineered with one common assembly procedure. The assembly line starts with either a starter or a/c pump and the car is then built around it. That's why the flat rate to r&r an a/c compressor on a Jetta is 14 hrs.
stanski is offline
post #13 of 25 (permalink) Old Aug 2nd, 18, 2:30 AM
06 dodge avenger...... starter is underneath the upper intake plenum. super fun.
BlakeSixty8 is offline
post #14 of 25 (permalink) Old Aug 2nd, 18, 6:17 AM
Terry
....but they usually dont have to.
TerryAT is offline
post #15 of 25 (permalink) Old Aug 2nd, 18, 7:48 AM
BUUUUUUURRRRNNNNNN! so true. I have a 92' Honda accord wagon, and the Mrs a 14' rouge, Japanese cars are the most reliable, plain and simple....
This Thread is more than 699 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
