Chevelle Tech - View Single Post - Tach gets interference from headlights, brakes, and horn
post #4 of (permalink) Old Dec 28th, 18, 5:33 AM
Gtogeoff
Geoff
Re: Tach gets interference from headlights, brakes, and horn
I would connect a voltmeter across the battery & check it once the engine has fired. Look for any over voltage [ higher than 14.5 v ] or voltage spikes. If you get any of these, the wiring in the charging cct should be checked for bad connections &/or alt & volt reg checked.
Gtogeoff is offline
