Chevelle Tech - View Single Post - Horn button wiring
post #1 of (permalink) Old Dec 20th, 18, 8:44 PM Thread Starter
Dannnnnn
Horn button wiring
Hey all, planning on installing a horn in my '72 Elco this weekend (original horn/wiring was removed by PO) and have some questions..
The back of the steering wheel button (pic attatched) has one male connector where it looks like one wire may have ran up to it thru the largest hole next the nut at the end of the steering column, is this correct?
If so i'm guessing the button is already grounded thru the mounting screws and I would just need to run 1 control wire from the relay up thru the column and to the connector on the button, and the other to ground, and should work?
Any insight would be much appreciated!
Sent from my SM-N950U using Tapatalk
1972 El Camino SS 350ci TKO-600
1953 Plymouth, chopped and channelled
2006 Crown Vic Police Interceptor
Dannnnnn is offline
