Chevelle Tech - View Single Post - Helpful Headlight Switch Info
post #37 of (permalink) Old Nov 17th, 18, 4:51 PM
paul bell
Re: Helpful Headlight Switch Info
Thread from the dead!
Dean, thanks for starting this thread, plenty good info in it.
Either I missed it or it hasn't yet been discussed, I have two questions. I'm working on a 1971 car.
Is there a fuse or circuit breaker in the headlight switch?
Is the high beam indicator lamp (the blue dot in the cluster) fed from the high beam wire from the floor high beam switch? It looks like these two wires are joined at the bulkhead connector.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
