Chevelle Tech - View Single Post - Valve Retainers and locks
post #13 of (permalink) Old Nov 11th, 18, 9:42 PM Thread Starter
1967 chevelle
Re: Valve Retainers and locks
The Edelbrock Valve Diameter Is 11/32" here are the specs for the following parts;
Manley Street Master Steel Retainers 1.550" Spring O.D.
1.550'' Spring O.D.
Double/Triple Spring Type
(A) 1.500'' O.D.
(B) 1.130'' I.D.
(C) 0.735''
(D) 0.640''
Standard Height
10° Keeper x ''All'' Valve Stem
29 Grams
16/pkg.
Manley 10° Steel Valve Locks 11/32" Valve Stem (.3415" )
11/32'' Valve Stem (.3415'')
Conventional Groove
Standard Height
6.8 grams
16/pkg
I called Manley up and sent them pictures and they said it looks totally normal.
The rocker arms poly nut has 0.485" of thread engagement on the ARP rocker studs which works out to be 9.5 turns, I was told 5 turns was minimum.
Name:	Valve train 001.jpg
ID:	578664   Click image for larger version
Name:	Valve train 002.jpg
ID:	578666   Click image for larger version
Name:	Valve train 003.jpg
ID:	578668   Click image for larger version
Name:	Valve train 004.jpg
1967 Chevelle Oshawa Built Car
-427 .60 over, Lunati 60211 Roller cam
-Super T10 2.64
-Dana 60 3.54 Posi
1967 chevelle is offline
