Chevelle Tech - View Single Post - Return fuel line on 1970 el Camino
post #21 of (permalink) Old Nov 2nd, 18, 8:30 AM
hydro462
Re: Return fuel line on 1970 el Camino
You can just tee the supply side going to the carb and run it back to the tank using 1/4" tubing..
I had all kinds of smell and bogging issues until I switched tanks to the one with the three ports at the top front. I blocked two and ran a looped hose to the middle with a gas filter on the end.. You could run your return into one of those..
hydro462 is offline
