Chevelle Tech - View Single Post - Charging system questions / 71, 350 two barrel, all stock
post #9 of (permalink) Old Aug 22nd, 18, 10:39 AM Thread Starter
ysr_racer
Brad g.
Re: Charging system questions / 71, 350 two barrel, all stock
Thanks. With the ignition off, doors closed, lights off I'm measuring 12.7 volts between the negative post on the battery, and the disconnected negative battery cable.
I removed the fuses one by one until everything was out of the fuse box, still 12.7. Shouldn't it be zero?
Yes it has an external regulator. I pulled out out. It's literally brand new. I pulled the alternator and took it in, it passed the test three times.
Even though I have 12.7 volts from the battery to the cable, it won't light up my continuity tester.
Am I doing this right?
ysr_racer is offline
