Chevelle Tech - View Single Post - No power with key on after new starter
post #5 of (permalink) Old Aug 12th, 18, 3:28 PM Thread Starter
PoorMansXcuse
Re: No power with key on after new starter
Here's a visual breakdown of what's going on. I tried to insert the pictures in the text, but haven't done that before. There is one wire from the positive side of the battery to the starter and a wire coming off that same starter post. It splits into 4 with these connections
One goes to this connection on the firewall and back out to the alternator post.
Another goes to the positive side of the alternator harness.
The last 2 go in behind the fuse block in this look.
I verified power to all these points and at the pwr/account, horn, bat, lighting. When I turn the key to run nothing to the fuses.
I had not yet checked the under hood wires key on, so I did and didn't get power. I then started at the battery, got power, starter post and down the line I had power everywhere. Turned the key and single click. I'm pretty confused about what it could be.
Sent from my moto g(6) using Tapatalk
PoorMansXcuse is offline
