Chevelle Tech - View Single Post - No Interior Lights - Help Needed
post #26 of (permalink) Old May 24th, 18, 10:39 AM
paul bell
Re: No Interior Lights - Help Needed
Was it already mentioned that the little inst light fuse gets its power is from the taillight fuse so you will notice it when you have no taillights.?
Actually Dean, this is partially true. The headlight switch gets its feed from what's marked on the fuse block as "tail" (which also feeds other things) so although the "inst" fuse is not connected to the tail fuse, the rheostat which feeds the "inst" fuse indirectly gets it's feed from the tail fuse.
Having said this, if the tail fuse was blown, the headlights won't work-as well as what looks to be the feed to the ignition switch.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is online now
