Chevelle Tech - View Single Post - 65 SS Chitvelle - My PT attempt
post #319 of (permalink) Old May 10th, 18, 11:40 AM
Jeff65SS
Re: 65 SS Chitvelle - My PT attempt
Originally Posted by Dan65ss View Post
I went with the Ididit in black. Although I was told they are exactly the same inside as the Flaming River.
Needed the different rag joint for the jeep steering box splines. And I need some kind of mount to hold the steering shaft at the firewall. The nice ones don't look like have enough clearance next to the clutch and hydraboost adapters.
Going to hit it hard the next few weeks and hopefully get it into body shop/paint in June...We will see.
Dan, I bought a stock repop steering column firewall mount for a stick car. The clutch master fits nicely in the old manual linkage hole. I even bought the rubber bellows for the stock linkage and modified it to fit over the clutch master so it will be water tight.
I getting ready to pull the trigger on a Ididit black column also, collapsible intermediate shaft and joints this weekend.
Jeff Evans
65 Chevelle, LS3/T56 transplant in progress
67 Chevelle, ZZ502, AFR 305, Straub Solid Roller, 400 Turbo, Moser Rear 3.42 gear
Jeff65SS is offline
