Chevelle Tech - View Single Post - STEWIE'S ENGINE SWAP/vacuum lines, rochester 2GV carb etc.
post #3 of (permalink) Old Aug 15th, 06, 8:21 AM
Xtreme70SS396
Mark
Re: STEWIE'S ENGINE SWAP/vacuum lines, rochester 2GV carb etc.
I believe A is the EGR valve and should be connected to vacuum source at base of carb or from manifold.
Been a LONG time since I worked on a 2bbl rochester, don't remember where all the lines go.
Interested in hearing about those vacuum lines!
Mark
1970 SS396
Lewis Racing Engines (
) 489:
634 HP @ 6000rpm
627 Lb-ft @ 4,000rpm
Gear Vendors Overdrive
Moser 12 Bolt
Radiator
Pypes Exhaust
Xtreme70SS396 is offline
