Chevelle Tech - View Single Post - 1969 Fuel Gauge Stuck?
post #3 of (permalink) Old Oct 2nd, 17, 8:08 PM
oldcutlass
Re: 1969 Fuel Gauge Stuck?
If you remove the wire to the sender with the key on, your gauge will drive past full. If you ground that same wire the gauge will go to empty. If both of these things happen then your sender is no good.
oldcutlass is offline
