Chevelle Tech - View Single Post - Front End Lift
Thread: Front End Lift
post #3 of (permalink) Old Aug 11th, 06, 11:42 PM
Philip
Re: Front End Lift
First determine if your car is at stock ride height. If the springs are sagging just replacing with new stock coils will raise the car.
I raised a 68 up about 2 inches over stock ride height by using big block springs in the front and wagon springs in the rear. There is also a thick rubber spacer available that goes in the top spring pocket. Anything inserted in between the coils is trouble waiting to happen.
63 Nova wagon
Philip is offline
