Blowing Fuses !!!!!!! - Chevelle Tech
1999 -- Tech Files - reference area
1000's of previous topics
post #1 of 5 (permalink) Old Jun 30th, 99, 9:05 AM Thread Starter
jr
I have a problem with my 67 SS Chevelle blowing fuses like crazy ! The problem is that every time I turn on the parking lights and turn the knob to INCREASE the dash lights so you can see them,,, I get a blown fuse ! I have replaced the light switch with a new one and still the same problem.
Now this is the scary part, the fuse that keeps blowing is on the very bottom of the fuse box and it is NOT the insterment fuse that one would expect to be blowing.
I have had that one blow also but not like the other one that controls the brake lights,
is there anyone out there that has a problem close to this ?
Thanks,
jr
jr is offline
post #2 of 5 (permalink) Old Jun 30th, 99, 11:19 AM
I can not say I have had this problem. All I can offer is some general information. Everytime I have had a strange electrical problem it has always been caused by a bad ground. Check your dash grounding then expand to the circuit with the blown fuse.
Good luck.
tom wurm is offline
post #3 of 5 (permalink) Old Jun 30th, 99, 2:57 PM Thread Starter
jr
Thanks Tom,
I will try the grounds under the dash and
the ones from the firewall to the valve covers ( I read that one somewhere in hear this morning although I don't know if it will pretain to my problem)
jr
jr is offline
post #4 of 5 (permalink) Old Jun 30th, 99, 4:40 PM
also be sure to check the hot leads... I had a bad problem once with a "Hot Ground" took out every, yes every light in the car and the regulator weep weep
Francis Taracido
[email protected]
Proud Patron of Quadzilla
Quadzilla is offline
post #5 of 5 (permalink) Old Jun 30th, 99, 6:09 PM
i would have to say a hot lead also,being it happens when you increase the dimmer.maybe the switch itself?look for a chaffing wire.
67 rat member #199
67RAT is offline
This Thread is more than 7293 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
