lower ball joint fit problems - Chevelle Tech
1999 -- Tech Files - reference area
1000's of previous topics
post #1 of 4 (permalink) Old Jan 8th, 00, 4:24 PM Thread Starter
The ball joint in my lower control arm managed to work its way loose even after I had it professionally pressed in, is there anyway to make it fit snug again or do I have to get another control arm with a smaller opening?
EddieT is offline
post #2 of 4 (permalink) Old Jan 8th, 00, 4:37 PM
Hoarder Deluxe
If it actually worked loose from the control arm, I would think the hole would now be egged and would need some work. Myself I dont like to take chances with suspension parts and would replace the arm with a good used one. If you are bucks down and know someone with the right tools I suppose it could be welded up and reground to the right dimension. But I would seriously consider getting another arm, should be $50 or less.
70 chevelle ss396 conv
66 chevelle ss396 hdp/conv
55 chevy prostreet
drptop70ss is offline
post #3 of 4 (permalink) Old Jan 8th, 00, 4:40 PM
Eddie I agree with droptop, don't chance it! mgg
Manny Gomez is offline
post #4 of 4 (permalink) Old Jan 8th, 00, 10:04 PM
Eddie, What year car? Does it have a disc conversion where the lower ball joint had to be modified? Maybe it was cut to small. At any rate you should find another control arm. There shouldn't be any problems finding one.
Philip Valentine
Gold Member #42
"Perseverance is not a long race; it is many short races one after another."
[email protected]
Philip is offline
This Thread is more than 7454 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
