| Chevelle Tech Current Topic: inexpensive conversion kit! | ||
| Brake Conversions Tech info on converting from drum to disc |
So far the least expensive complete kit I have found is $619.00. Has any one found one at a better price? Thanks again for all your help guys!
Brian |
#2
Is that the guy in Ohio? You could look on eBay (if you haven't done that already), I have seen another guy selling similar kits. If I remember correctly, he was in the same ballpark, so you might be able to use that to haggle a bit.
1969 Malibu in progress |
Yeah, same guy. Looks like it's going to be $619.00.
I got my spindles for 100 and all together, including new flex hoses I have about 350 in mine from Autozone.
1969 SS396 Monaco Orange 4 speed 12 bolt 489 big block 2003 Silverado SS AIM= YenkoChevelle69 1969 Chevelle Quarter Panel Replacement |
I was going to mention what Yenko said. Just buy a set of spindles and get the rest at the parts store. Im thinking around 500 bucks to put it together but I havent actually tried. My 66 already had 70 discs already on it.
Chris. If it aint broke, just give me a minute. |
#6
Or, modify your spindles and get everything else at Autozone. Caliper brackets are $85 at our sponsor. GroundUp.
#7
![]() Even if you can modify your spindles like Cam Sweet says, I doubt that it really pays off to buy the rest from Autozone. If you want to save money, I'd say that a cheap but complete used setup would be the best start, so you can use calipers, m/c, booster etc for cores, or even rebuild them yourself. Used (or modified) spindles, caliper brackets and dust shields (if you can find them) is probably the best way to save money if you want to use new parts for the wear items.
#8
As always I appreciate all the input. Sounds like if I want the job to be somewhat headache free, w/o a lot of running around, and spending time searching I should just buy the complete kit. By the way I've posted another topic, which has had no replies, It looks like when I install a booster it will hit my wiper motor an shift linkage on the coloum. Can anyone help me here? Thanks AGAIN,
Brian |
#9
PM me if you need pix of the installation in my -69. I have a column shifter too, and there are no clearance problems.
#10
Where is this place at???? For roughly $620 for a disc brake conversion, I gotta know who, where, etc. Any links or phone numbers??? Thanks!
http://myspace.com/lxs14 '71 Chevelle 388ci (Untuned best of 8.373@83.05mph 1/8th mile on tires and 8.236@84.40mph on slicks) '95 Burban 6" lift on 36s (for sale) '02 Mustang Vert, CAI and SLP Loud Mouth cat back (Gone )'61 VeeDub Bug Ragtop '07 Ford Five Hundred (The "Red Headed Step Child" ) '03 Mach 1 |
#11
#12
just what I need! tell me more guys - - must have posted in the wrong brake area
i have disc on front but need rear.....she slides. not stops. give me an idea what i should be asking and looking for? i am LOST when it comes to brakes. THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! rachael anne
Buttercup '66 Malibu 4 dr for sale '70 Chevelle SS 396 '71 Camaro 350 in pieces ![]() '06 Silverado Z71 4x4 '07 Avalanche LTZ 4x4 Team Chevelle #0796 ACES #05033 Carolina Chevelle Assoc. #70 Women who behave rarely make history. "Because fast enough...never is" |
#13
#14
Rach,
You probably just need a prop. valve piped into the rear line is all. pdq67 |
#15
I think that what i need pdq - have been cking it out but am headed to Columbia as of Thursday am...will see you there probably! I am SO glad to be going home!!!!
rachael anne
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| HEI Conversion Kit | tmino | Engine | 0 | Aug 8th, 05 11:19 AM |
| 4 Door Power Window Kit on Ebay | Brad | Chevelle Tech | 3 | May 18th, 05 11:04 AM |
| Installing electronic ignitions conversion kit ?'s | james a larson | Electrical & Wiring | 0 | May 15th, 05 7:56 PM |
| 1964 malibu ss 4 speed conversion | G64ss | Transmission & Driveline | 1 | Apr 13th, 05 10:57 AM |
| Help- SS dash, console conversion | lindsay | 1999 -- | 2 | Dec 27th, 99 10:39 PM |
